Help with connecting a JLink EDU
veggie2u_cyberward
Post by veggie2u_cyberward »
I am wanting to learn how to debug code on device. I am familiar with debugging in java & javascript, but not in C and not on the device. I have a JLInk EDU, and I have tried with a Metro Express M0, and a Grand Central. Nothing will connect. I even just got a second JLink EDU because I thought it might not be working. I should say I am on a MacBookPro with USBC only ports and an adapter. I can load code to these and other boards just fine with Arduino and PlatformIO.
What I tried first was the article by Scott on using GDB https://learn.adafruit.com/debugging-th ... -gdb/setup. I got to the point where I type the command:
JLinkGDBServer -if SWD -device ATSAMD21G18
I do get some output. It tries to connect, but always gives this
2449 ~  » JLinkGDBServer -if SWD -device ATSAMD21G18
SEGGER J-Link GDB Server V7.54c Command Line Version
JLinkARM.dll V7.54c (DLL compiled Sep 20 2021 13:55:08)
Command line: -if SWD -device ATSAMD21G18
-----GDB Server start settings-----
GDBInit file:                  none
GDB Server Listening port:     2331
SWO raw output listening port: 2332
Terminal I/O port:             2333
Accept remote connection:      yes
Generate logfile:              off
Verify download:               off
Init regs on start:            off
Silent mode:                   off
Single run mode:               off
Target connection timeout:     0 ms
------J-Link related settings------
J-Link Host interface:         USB
J-Link script:                 none
J-Link settings file:          none
------Target related settings------
Target device:                 ATSAMD21G18
Target interface:              SWD
Target interface speed:        4000kHz
Target endian:                 little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link EDU Mini V1 compiled Sep 24 2021 16:44:11
Hardware: V1.00
S/N: 801035568
Feature(s): FlashBP, GDB
Checking target voltage...
Target voltage: 3.30 V
Listening on TCP/IP port 2331
Connecting to target...
ERROR: Could not connect to target.
Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
Shutting down...
Please check power, connection and settings.%
The other 2 posts I saw on the Learn site were for windows, so I have not tried them. I saw a post that says the JLink does not work with a VM.
I then saw a post here about using Ozone. So I tried that. I downloaded it and couldn't figure out how to give it a project file. I tried the wizard, and thought it was working (SWD mode???) but it also says "Connection failed" I have no idea what I am doing in that program yet though.
I am kind of at a loss. Would be grateful for any direction at this point. The end goal is probably to use JLink with PlatformIO - I have switched to it from the Arduino IDE recently, but at this point I would just like to prove that it works.
User_UMjT7KxnxP8YN8
Re: Help with connecting a JLink EDU
Post by User_UMjT7KxnxP8YN8 »
How are you connecting the J-Link to your board?
veggie2u_cyberward
I am using the short micro usb cable and ribbon cables that came with the Jlink and an adapter cable that I have also used to upload to this and other devices. I have tried powering the Metro with 5v from a power adapter, not USB port at its micro USB port, and 9v via the barrel jack.
Meto Express Wires
Meto Express Wires
adafruit_support_carter
Rotate connection here 180deg.
Red line on ribbon cable indicates Pin 1 location. Pin 1 on JLink:
veggie2u_cyberward
Well golly G willikers. That did it. I did not read that as a pin one identifier. I am not sure that there is a picture anywhere of that cable plugged in. I looked in the Segger manual and didn't see one. One on the Adafruit site would be a good idea I think. Thank you.
Any suggestions on how best to get started debugging using this tool now that I have it working?
User_UMjT7KxnxP8YN8
Return to “Metro, Metro Express, and Grand Central Boards”
