Adding SPI help Grand Central M4
- ericmkube
Hi all. I've been trying to add another SPI bus to my board to replace sercom5. I've tried several different combinations of pins, but all efforts are failing. I followed the muxing guide but realized that the pins used are not correct so I followed the board schematic and the datasheet for the samd51 instead. I've been trying to edit the variant file to include an SPI bus 2. The bus gets created but doesn't seem to work as the device I'm trying to connect to fails to be detected and works when connected to the native supporter SPI bus. Does anyone have a good combination of pins and sercom to use to accomplish this? It does not need to be on sercom 5, but I will need to keep the i2c bus intact. I am not using uart.
- mikeysklar
Re: Adding SPI help Grand Central M4
@ericmkube,
One forum user came up with a set of pins that worked for a SERCOM additional SPI with a Grand Central M4.
viewtopic.php?f=63&t=153721&p=758759&hi ... m4#p758759
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#include "wiring_private.h" // pinPeripheral() function
SPIClass SPI2 (&sercom5, 9, 11, 12, SPI_PAD_2_SCK_3, SERCOM_RX_PAD_0);
#define BME_SCK 11
#define BME_MISO 9
#define BME_MOSI 12
#define BME_CS 10
#define SEALEVELPRESSURE_HPA (1013.25)
//Adafruit_BME680 bme; // I2C
Adafruit_BME680 bme(BME_CS); // hardware SPI
//Adafruit_BME680 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK);
Serial.begin(9600);
pinPeripheral(9, PIO_SERCOM);
pinPeripheral(11, PIO_SERCOM_ALT);
pinPeripheral(12, PIO_SERCOM);
SPI.setModule(2);
while (!Serial);
Serial.println(F("BME680 test"));
if (!bme.begin()) {
Serial.println("Could not find a valid BME680 sensor, check wiring!");
while (1);
- ericmkube
This worked for me. Thanks
- mikeysklar
Awesome. Did you need to make any changes?
