My pygamer works seldom and when it does, the screen display is faint. I went on Youtube last night and saw what the display is supposed to look like. Mine has never looked like that. I have ordered a new one, but would like a replacement for the one I have as well.
- Craig
Pygamer
- adafruit_support_carter
Re: Pygamer
Is the board otherwise running OK?
Can you post some photos so we can look for anything obviously wrong with the hardware.
- craigcooper
Re: Pygamer
"is the Pygamer running well aside from that?"
I can not see the screen. How would I know.
Charging my phone and will send photos when available.
- craigcooper
Re: Pygamer
Here are a few photos.
All green neopixels after a double reset
dim green on the left and four bright white on the right when pressing reset once after it has been double pressed
- craigcooper
- craigcooper
- IMG_2633.JPG (384.69 KiB) Viewed 426 times
- IMG_2630.JPG (121.67 KiB) Viewed 426 times
- IMG_2631.JPG (309.77 KiB) Viewed 426 times
Re: Pygamer
This sounds correct and good. Are you also seeing the PYGAMERBOOT folder showing up on your PC at the same time?All green neopixels after a double reset
Re: Pygamer
Cool. We can try a self test. Download the UF2 file linked from the green box at the top of this page:
https://learn.adafruit.com/adafruit-pyg ... shooting-2
Drag the UF2 file to the PYGAMERBOOT folder. It should reset once the copy is complete and run the example. Any change to the screen?
Re: Pygamer
Is this a new Pygamer? It's been like this out of the box?
- craigcooper
Re: Pygamer
It is new. It has been like this out of the box. I have been trying to get this to work, assuming it was a working product. From time to time, the display will come on, faint and only for a short time.
- Craig
- Craig
Re: Pygamer
OK, let's just replace it. Not sure what's going on, seems like something marginal, but probably not something easily user fixable.
Send an email to [email protected] with a link to this thread and your order number and they can send you a replacement PyGamer (PID 4242).
