Hi all, with various example code projects for my metro, I have found that pressing the reset button causes the code to either resume or restart (I assume restart)... which is awesome.
However, with my own project... this behavior is not happening. If I press reset, no code runs.
My goal/intent is to have my project survive a reset, but ESPECIALLY a power-cycle.
Any help appreciated.
Reset Button = restart code?
- dastels
Re: Reset Button = restart code?
What programming language are you using?
Can you post your code?
- SkyRyder
Hi Dave... yessir!
all in c
all in c
#include "Adafruit_MCP9601.h" //for thermocouple. This is a Header file.
#include "SPI.h" //for display
#include "Adafruit_GFX.h" //for display
#include "Adafruit_ILI9341.h" //for display
#include <Wire.h> //for relay
#define COMMAND_RELAY_OFF 0x00 //for relay
#define COMMAND_RELAY_ON 0x01 //for relay
#define COMMAND_CHANGE_ADDRESS 0x03 //for relay
//The actual default address is SUPPOSED to be 0x18, but 0x19 is what works!
volatile byte qwiicRelayAddress = 0x19; // Set Address for relay
// For the Adafruit shield, these are the default.
#define TFT_DC 9 // for display but what?
#define TFT_CS 10 // for display but what?
#define TEMP1_ADDRESS (0x67) //for thermocouple
Adafruit_MCP9601 mcp; //for thermocouple
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
// If using the breakout, change pins as desired
//Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC, TFT_MOSI, TFT_CLK, TFT_RST, TFT_MISO);
void setup()
Serial.begin(9600); //sets the rate for the serial monitor output only! (not I2C)
while (!Serial) { // wait for serial to come up
delay(10); // 10ms delay
// This may not be needed since the TC module is also using Wire
Wire.begin(); // join the I2C Bus (relay)
Wire.beginTransmission(qwiicRelayAddress); // transmit to device
//check here for an ACK from the slave
Serial.println("begin wire transmission test");
if (Wire.endTransmission() != 0 ) {
Serial.println("Check Connections. Slave not found.");
else {
Serial.println("Qwiic Relay found at 0x19!");
Serial.println("MCP9601 TC + Display test"); // Send to serial monitor
/* Initialise the driver with XXX_ADDRESS and the default I2C bus. */
if (! mcp.begin(TEMP1_ADDRESS)) {
Serial.println("Thermocouple not found. Check wiring!");
while (1);
mcp.setADCresolution(MCP9600_ADCRESOLUTION_18); //set TC resolution to 18 bits
mcp.setThermocoupleType(MCP9600_TYPE_K); //set TC type to K
mcp.setFilterCoefficient(3); //not sure what this does
mcp.enable(true); //not sure what this does
tft.begin(); // start display process?
delay(10); // delay needed to prevent display inversion?
tft.setRotation(1); // initialize the desired screen rotation
delay(10); //not sure why delay is here
Serial.print(F("Screen fill "));
Serial.println(testFillScreen());
delay(500);
// Serial.print(F("Text "));
// Serial.println(testText());
// delay(3000);
tft.fillScreen(ILI9341_BLACK);
yield();
//why is void in the arguments?
void loop(void) {
// uint8_t status = mcp.getStatus();
// Serial.print("MCP Status: 0x");
// Serial.print(status, HEX);
// Serial.print(": ");
// if (status & MCP9601_STATUS_OPENCIRCUIT) {
// Serial.println("Thermocouple open!");
// return; // don't continue, since there's no thermocouple
// if (status & MCP9601_STATUS_SHORTCIRCUIT) {
// Serial.println("Thermocouple shorted to ground!");
// return; // don't continue, since the sensor is not working
tft.setCursor(0, 0);
//text color to green and background to black
tft.setTextColor(ILI9341_GREEN,ILI9341_BLACK);
tft.setTextSize(2);
tft.println("Tiny Recirculator");
tft.println(mcp.readThermocouple()*1.8+32); //print calculated value
relayOn();
delay(2000);
relayOff();
// for(uint8_t rotation=0; rotation<4; rotation++) {
// tft.setRotation(1);
// testText();
// delay(1000);
// testText();
// delay(1000);
/* Begin function definitions.... */
unsigned long testFillScreen() {
unsigned long start = micros();
yield();
tft.fillScreen(ILI9341_RED);
yield();
tft.fillScreen(ILI9341_GREEN);
yield();
tft.fillScreen(ILI9341_BLUE);
yield();
yield();
return micros() - start; // this calculates how long it took to fill screen
//The following is a whack text display... needs much work
unsigned long testText() {
// tft.setTextColor(ILI9341_WHITE); tft.setTextSize(1);
// tft.println("Hello World!");
// tft.setTextColor(ILI9341_YELLOW); tft.setTextSize(2);
// tft.println(1234.56);
// tft.setTextColor(ILI9341_RED); tft.setTextSize(3);
// tft.println(0xDEADBEEF, HEX);
// tft.println();
tft.setTextColor(ILI9341_GREEN);
// tft.setTextSize(5);
// tft.println("Groop");
tft.setTextSize(2);
tft.setTextSize(1);
tft.println("Ver 1.0");
// tft.println("And hooptiously drangle me");
// tft.println("with crinkly bindlewurdles,");
// tft.println("Or I will rend thee");
// tft.println("in the gobberwarts");
// tft.println("with my blurglecruncheon,");
// tft.println("see if I don't!");
void relayOn() {
Wire.write(COMMAND_RELAY_ON);
if (Wire.endTransmission() != 0) {
Serial.println("Check Connections. No slave attached");
// RelayOff() turns off the relay at the qwiicRelayAddress
// Checks to see if a slave is connected and prints a
// message to the Serial Monitor if no slave found.
void relayOff() {
Wire.write(COMMAND_RELAY_OFF);
- dastels
You might need to have a terminal program running & connected to the USB/Serial port of the board.
- SkyRyder
Oh? what does that do for me? Not sure where this is leading...
- dastels
Your setup starts with
That often/generally (I'm not sure of the details behind it) waits for a connection to be established before continuing on.
- SkyRyder
Thanks, Dave...
So what you're saying is that a port needs to be available for the code to escape that loop...
So with the arduino connected to my pc and the IDE... I do have an open port window... but it still doesn't do anything.
But you are thinking that if I didn't start up the serial device... then it might just boot properly?
[Edit: I tested this... and you are entirely correct. That is the part that was biffing it.]
I'm pretty sure I've seen example code that starts up fine on reset while running the serial port...
Is there a way to write to the serial port in a way that is entirely benign to all other code execution?
- dastels
I've seen code that uses a call to delay to wait a bit after the Serial.begin() call. I generally use a different approach: selectively using Serial based on a build flag. I have a logging package that I configure through build flags: what to log and where to put the output. So a release build will just log errors and put it on an SD card and/or indicate using a NeoPixel, while I debug build will log everything and send it to Serial.
You can see my latest use of it in https://github.com/dastels/wrist_computer. Look in src at the logging and handler classes.
- SkyRyder
Thank you, Dave!!
