I have been doing sketches for some time on my Mega 2560 and have moved over (trying..) to the Grand Central and have a compile issue and can't find an example of how this should be re-written.
This modified Blink sketch does compile for the Mega and does not for the Grand Central...
The parts I have added are pieces of a larger sketch that (this part) write over to another board using i2c, an output state for a tension control, where one motor is set to turn clockwise and the other, counter clockwise (and vice-versa).
#include <Wire.h>
unsigned int duration;
Blink
Turns an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
the correct LED pin independent of which board is used.
If you want to know what pin the on-board LED is connected to on your Arduino
model, check the Technical Specs of your board at:
https://www.arduino.cc/en/Main/Products
modified 8 May 2014
by Scott Fitzgerald
modified 2 Sep 2016
by Arturo Guadalupi
modified 8 Sep 2016
by Colby Newman
This example code is in the public domain.
https://www.arduino.cc/en/Tutorial/BuiltInExamples/Blink
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
LoosenTension();
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
TightenTension();
void LoosenTension() {
setDurTension(9, (unsigned int)100); // infeed direction 1100 is normal 100 is backwards = to loosen
setDurTension(10, (unsigned int)1100); // exit direction 100 is normal 1100 is backwards = to loosen
void TightenTension() {
setDurTension(9, (unsigned int)1100); // infeed direction 1100 is normal 100 is backwards = to loosen
setDurTension(10, (unsigned int)100); // exit direction 100 is normal 1100 is backwards = to loosen
void setDurTension(uint8_t DAC, unsigned int duration) { //Tension Bool to make a pin low or high to enable or disable tension 9 and 10 are direction 11 and 12 are frequency
Wire.beginTransmission(10);
Wire.write(DAC);
const unsigned char val1 = duration & 0xFF;
const unsigned char val2 = (duration >> 8) & 0xFF;
Wire.write(val1);
Wire.write(val2);
Wire.endTransmission();
Any thoughts are appreciated!
Thanks, Gary
