Apologies for the noob queston, I'm very new to circuit python.
How do I manage my python programs for my metro express.
As I understand it, the current program must be named code.py and be located in the root directory.
So, lets say I'm running a blinking led program and want to work on something different
I have to:
rename code.py to blink.py
rename double_blink.py to code.py
Is this correct?
This feels very clunky.
I'm hoping there's something I missed.
How to manage files for Metro Express
- dastels
Re: How to manage files for Metro Express
Typically you have a single application on a microcontroller board.
Personally, I don't actively develop on the board. I work on code on my workstation's drive and copy things to the board to test/run it using a deploy script: https://github.com/dastels/circuitpython_deploy.
- stampmaille
Thank you for your reply.
Unfortunately I'm too much of a noob to understand how to run a script or use github.
I thought I'd learn Python by converting my Arduino programs to run on a Metro Express and was hoping to lessen the learning curve.
Any other tips?
Thanks in advance.
Any other tips?
Thanks in advance.
- dastels
Have a different directory (on your host system) for each project. Have code.py in that directory and copy it to CIRCUITPY when you want to test/run it. That's mostly what my script does, and also manages the libraries needed for the project.
If you have a lot of code, it's useful to separate it into multiple files, typically one per class. In this case I use main.py instead of code.py.
Learning the basic use of Github is pretty much a requirement these days. Git can do amazing things, but you generally don't need more than a few commands. There are plenty of introductions to Git and Github. I'd start by looking at github.com.
