Metro Express - Either I or the Board is Terribly Inadequate
HenryM
Post by HenryM »
Edit: I'm using CircuitPython 7.0.0
My goal is to drive three 14-segment alphanumeric displays using a Metro Express M0 and, well, it just doesn't seem up to the challenge. Essentially, right now, I have a single neopixel (the one included on the board) and I'm trying to import the ht16k33 library. Here's my code:
main.py
import board
import neopixel
import digitalio
import busio
from adafruit_ht16k33 import segments
i2c = busio.I2C(board.SCL, board.SDA)
pixel = neopixel.NeoPixel(board.NEOPIXEL, 1)
pixel.brightness = 0.1
while True:
    pixel[0] = [255, 0, 0]
    time.sleep(0.1)
    pixel[0] = [0, 0, 0]
    time.sleep(0.9)
  File "main.py", line 7, in <module>
  File "adafruit_ht16k33/segments.py", line 392, in <module>
MemoryError: memory allocation failed, allocating 96 bytes
mikeysklar
Re: Metro Express - Either I or the Board is Terribly Inadeq
Post by mikeysklar »
HenryM,
Can you try loading the MPY library files (pre-compiled) for segements / neopixel. You had been calling the PY file which is larger. Also please make sure you are running CircuitPython 7.x
https://github.com/adafruit/Adafruit_Ci ... 211202.zip
HenryM
Post by HenryM »
As far as I know, I have been using the precompiled binaries. Everything within `adafruit-circuitpython-bundle-7.x-mpy-20211202/lib` is precompiled? And I do confirm that I've been using CircuitPython 7.0.0.
mikeysklar
@HenryM,
I have both bundles of source and compiled files. Since your error in the REPL had the source file extension of *.py versus the compiled extension of *.mpy I think you might be using the source files. Can you check your CIRCUITPY/lib folder to confirm what the file extensions are on your libraries?
In terms of how to verify the version of CircuitPython running on your device take a lok at CIRCUITPY/boot_out.py. It should look something like this:
$ cat boot_out.txt
Adafruit CircuitPython 7.0.0 on 2021-09-20; Adafruit Feather RP2040 with rp2040
Board ID:adafruit_feather_rp2040
HenryM
Post by HenryM »
Contents of boot_out.txt:
Adafruit CircuitPython 7.0.0 on 2021-09-20; Adafruit Metro M0 Express with samd21g18
Board ID:metro_m0_express
The files within the `lib` directory are almost all .mpy. The only exceptions are within the subdirectories, there are a few 0 length __init__.py files
HenryM
Post by HenryM »
I sincerely appreciate your suggestions mikeysklar. So thank you for the help.
For what its worth, I'm just going to do this project in Arduino mode. I didn't even intend to get something that would run CircuitPython, it was just something that was in stock and looked like it could easily handle what I want. When I saw that it was set up for CircuitPython by default, I decided to roll with it. I'm now using in "regular" Arduino mode and I'm able to pound the code out very quickly.
danhalbert
Post by danhalbert »
The backtrace will say (somewhat misleadingly) `.py` even if the file is `.mpy`.
Return to “Metro, Metro Express, and Grand Central Boards”
