DAC Dithering: How can I enable and use it?
AidanHockey5
Post by AidanHockey5 »
I was taking a look at the SAMD51 family datasheet and noticed that the DAC features a dithering mode.
https://www.mouser.com/datasheet/2/268/ ... 130176.pdf
Page 1681.
I have an audio application that involves signed, 16-bit stereo WAV data being fed to the two DAC pins in 12-bit resolution mode. Right now, I'm simply using some bitshifting to map the 16-bit signed sample data to the 12-bit unsigned DAC registers, like so:
void playWavSample()
    int16_t l = readBuf16(&wavStream);
    int16_t r = readBuf16(&wavStream);
    //16 bit signed to 12 bit unsigned conversion
     REG_DAC_DATA0 = ((l + 32768) >> 4); //Quickly write to the ADC A0
     REG_DAC_DATA1 = ((r + 32768) >> 4); //Quickly write to the ADC A1
I configure the DAC as follows before I run the above code:
  analogWriteResolution(12);
  analogWrite(A0, 0);
  analogWrite(A1, 0);
This works well for quickly pushing samples to the DAC, but I can't help but wonder if I could improve my audio quality by applying a bit of dithering to the output.
After doing a little Googling, I haven't seen anything on how to utilize the built-in dithering feature. I'm pretty new to operating the DACs with lower level code, so I would really appreciate some insight or examples since I don't entirely understand what the datasheet is instructing me to do.
My preferred result would be allowing me to push 16-bit audio samples to the dithering register and have it output result to the DAC pins.
If it's possible to leverage this dithering function, I think it would be great for others to potentially improve their audio applications too! Thanks!
Return to “Metro, Metro Express, and Grand Central Boards”
