Metro mini and Trinket M0 issues
AblazeRiver
Post by AblazeRiver »
Hi!
Neither my Trinket M0 nor my Metro Mini are being recognized on my computer as a serial com. They don't even show up in my USB device list.
I've been troubleshooting them for about two weeks: I've tried several cables, every USB port, and two different computers--a Mac that was recently updated and a PC running Windows 10. I've installed the drivers from you guys and SilLabs several times. I tried following the instructions on https://support.arduino.cc/hc/en-us/sec ... 0003198300 but there's no way to put these board into DFU mode.
I'm working on a project that has a really tight deadline and it's coming up soon. Any way I can get replacements shipped to me quickly, please? Also, should I cross-post this to the trinket forum?
Faulty items include:
Adafruit Trinket M0
Adafruit Metro Mini 328
order number: 2788693-4955311723
I'm including screenshots/error messages from the PC and photos of the metro mini because that's what's with me at work, I can include the other images when I get home.
(I think the IDE is trying to connect to my Arduino UNO board, which was not connected).
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
Sketch uses 1786 bytes (5%) of program storage space. Maximum is 32256 bytes.
Global variables use 13 bytes (0%) of dynamic memory, leaving 2035 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xa7
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sec ... 0003198300 for suggestions.
Changed my preferences to show verbose output during compilation and got:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\NeonBlond Prime\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101 -warnings=none -build-cache C:\Users\NEONBL~1\AppData\Local\Temp\arduino_cache_588409 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\NeonBlond Prime\Documents\Arduino\senketsu_randblink\senketsu_randblink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\NeonBlond Prime\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0000_0000 -ide-version=10819 -build-path C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101 -warnings=none -build-cache C:\Users\NEONBL~1\AppData\Local\Temp\arduino_cache_588409 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\NeonBlond Prime\Documents\Arduino\senketsu_randblink\senketsu_randblink.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\NEONBL~1\\AppData\\Local\\Temp\\arduino_build_634101\\sketch\\senketsu_randblink.ino.cpp" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\NEONBL~1\\AppData\\Local\\Temp\\arduino_build_634101\\sketch\\senketsu_randblink.ino.cpp" -o "C:\\Users\\NEONBL~1\\AppData\\Local\\Temp\\arduino_build_634101\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\NEONBL~1\\AppData\\Local\\Temp\\arduino_build_634101\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\NEONBL~1\\AppData\\Local\\Temp\\arduino_build_634101\\sketch\\senketsu_randblink.ino.cpp" -o "C:\\Users\\NEONBL~1\\AppData\\Local\\Temp\\arduino_build_634101\\sketch\\senketsu_randblink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\wiring_pulse.S.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\WInterrupts.c.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\wiring_analog.c.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\wiring_digital.c.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\wiring.c.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\wiring_pulse.c.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\hooks.c.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\wiring_shift.c.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\CDC.cpp.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\HardwareSerial1.cpp.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\HardwareSerial0.cpp.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\HardwareSerial.cpp.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\HardwareSerial2.cpp.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\HardwareSerial3.cpp.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\IPAddress.cpp.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\Tone.cpp.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\Print.cpp.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\Stream.cpp.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\PluggableUSB.cpp.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\WMath.cpp.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\WString.cpp.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\abi.cpp.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\main.cpp.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\new.cpp.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\USBCore.cpp.o
Using previously compiled file: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_build_634101\core\core.a
Archiving built core (caching) in: C:\Users\NEONBL~1\AppData\Local\Temp\arduino_cache_588409\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\NEONBL~1\\AppData\\Local\\Temp\\arduino_build_634101/senketsu_randblink.ino.elf" "C:\\Users\\NEONBL~1\\AppData\\Local\\Temp\\arduino_build_634101\\sketch\\senketsu_randblink.ino.cpp.o" "C:\\Users\\NEONBL~1\\AppData\\Local\\Temp\\arduino_build_634101/core\\core.a" "-LC:\\Users\\NEONBL~1\\AppData\\Local\\Temp\\arduino_build_634101" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\NEONBL~1\\AppData\\Local\\Temp\\arduino_build_634101/senketsu_randblink.ino.elf" "C:\\Users\\NEONBL~1\\AppData\\Local\\Temp\\arduino_build_634101/senketsu_randblink.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\NEONBL~1\\AppData\\Local\\Temp\\arduino_build_634101/senketsu_randblink.ino.elf" "C:\\Users\\NEONBL~1\\AppData\\Local\\Temp\\arduino_build_634101/senketsu_randblink.ino.hex"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\NEONBL~1\\AppData\\Local\\Temp\\arduino_build_634101/senketsu_randblink.ino.elf"
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x37
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x37
screenshot metro mini.JPG (90.44 KiB) Viewed 101 times
mikeysklar
Re: Metro mini and Trinket M0 issues
Post by mikeysklar »
These boards should be showing up in device manager or it more than likely means you have an invalid USB cable / port.
Are you able to verify a good cable / port with another microcontroller or USB device?
Return to “Metro, Metro Express, and Grand Central Boards”
