Hi all,
I’m new to the Adafruit Metro M0 Express. I’ve used it with a RGB Matrix Shield to run a 32 x 32 Neopixel Matrix. I’ve got some animations running well but wanted to add some buttons. From the remaining pins I deduced that I could use A4, A5 and 11. Unfortunately, when I programmed input_pullup via arduino ide they didn’t behave as I expected and I’m now wondering if their are internal pull up resistors. Is anyone able to advise also if I’ve messed up and I’m using a pin that’s already used by the RGB matrix I’d love that feedback too. Many thanks
Metro Express - Can pins be Input_pullup?
- adafruit_support_carter
Re: Metro Express - Can pins be Input_pullup?
They should. Can you provide more information on your setup. What is being wired to the A4/A5/11 pins? What is your indication they are not behaving as expected?
