///////////////////////////////// Nextion Library ///////////////////////////////////////
#include <SPI.h>
///////////////////////////////// DS18B20 Sensor Library ///////////////////////////////
#include <DallasTemperature.h>
#include <OneWire.h>
/////////////////////////////// RTC Inputs ///////////////////////////////////////////
//int chipSelect = 53 ;
int chipSelect = 3 ;
int intFreq = 4 ;
////////////////////////////// RTC ///////////////////////////////////////////////////
#define WRITE_CONTROL_REG 0x8E
#define READ_CONTROL_REG 0x0E
#define WRITE_TIME_REG 0x80
#define READ_TIME_REG 0x00
///////////////////////////////Data Wire Is Plugged into Pin 46 ///////////////////////////////////////////////////
//#define ONE_WIRE_BUS 46
#define ONE_WIRE_BUS 2
/////////////////////////////// Setup A oneWire Instance To Communicate With Any oneWire Device /////////////////
OneWire oneWire(ONE_WIRE_BUS);
//////////////////////////////Pass oneWire Reference to Dallas Temperature /////////////////////////////////////
DallasTemperature sensors(&oneWire);
////////////////////////////Assign The Unique Adresses Of oneWire Temperature Sensor ///////////////////////////
DeviceAddress ISOtank = {0x28, 0xAD, 0x61, 0x74, 0x06, 0x00, 0x00, 0xA3};
/////////////////////////////// RTC Code //////////////////////////////////////////////////
uint8_t mybuffer[4];
// float f;
//memcpy(&f, mybuffer, 4);
struct timeParameters{
uint8_t ss ;
uint8_t mm ;
uint8_t hh ;
uint8_t dy ;
uint8_t d ;
uint8_t m ;
uint8_t y ;
void RTC_init(int chipSelect, int intFreq){
* The DS3234 offers four output frequencies:
* Options:
* 1: 1 kHz
* 2: 1.024 kHz
* 3: 4.096 kHz
* 4: 8.192 kHz
* 5: OFF
pinMode(chipSelect, OUTPUT) ;
digitalWrite(chipSelect, LOW) ;
SPI.transfer(READ_CONTROL_REG) ;
byte origianlConfig = SPI.transfer(0x00) ;
digitalWrite(chipSelect, HIGH) ;
delay(10) ;
byte configModifier ;
byte newConfig ;
if (intFreq == 5){
configModifier = 0b10111111 ;
newConfig = configModifier & origianlConfig ;
else if (intFreq < 5){
uint8_t freqOption = intFreq -1 ;
configModifier = (freqOption << 3) | 0b1000000 ;
newConfig = configModifier | (origianlConfig & 0b11100011) ;
SPI.transfer(WRITE_CONTROL_REG) ;
SPI.transfer(newConfig) ;
delay(10) ;
static uint8_t convertValueIN(uint8_t value){
uint8_t convertedVal = value - 6 * (value >> 4) ;
return convertedVal ;
static uint8_t convertValOUT(uint8_t value){
uint8_t convertedVal = value +6 * (value /10) ;
void setTime(int chipSelect, timeParameters *timeVals){
SPI.transfer(WRITE_TIME_REG) ;
SPI.transfer(convertValOUT(timeVals->ss)) ;
SPI.transfer(convertValOUT(timeVals->mm)) ;
SPI.transfer(convertValOUT(timeVals->hh)) ;
SPI.transfer(convertValOUT(timeVals->dy)) ;
SPI.transfer(convertValOUT(timeVals->d)) ;
SPI.transfer(convertValOUT(timeVals->m)) ;
SPI.transfer(convertValOUT(timeVals->y)) ;
delay(10) ;
void readTime(int chipSelect, timeParameters *timeVals){
SPI.transfer(READ_TIME_REG) ;
timeVals->ss = convertValueIN(SPI.transfer(0x00)) ;
timeVals->mm = convertValueIN(SPI.transfer(0x00)) ;
timeVals->hh = convertValueIN(SPI.transfer(0x00)) ;
timeVals->dy = convertValueIN(SPI.transfer(0x00)) ;
timeVals->d = convertValueIN(SPI.transfer(0x00)) ;
timeVals->m = convertValueIN(SPI.transfer(0x00)) ;
timeVals->y = convertValueIN(SPI.transfer(0x00)) ;
digitalWrite(chipSelect, HIGH);
delay(10);
///////////////////////////////////////////// RTC Variable To Set Time ///////////////////////////////////////////////////
uint8_t s = 00;
uint8_t mi = 33;
uint8_t h = 20;
uint8_t da = 3;
uint8_t d = 22;
uint8_t mo = 3;
uint8_t y = 22;
timeParameters TimeNow = { s, mi, h, da, d, mo, y } ;
uint32_t timeTrigs = 0 ;
void timeFunc(){
timeTrigs += 1 ;
//////////////////////////////////////// Begin RTC ///////////////////////////////////////////////////////////////////
SPI.begin() ;
SPI.setBitOrder(MSBFIRST) ;
SPI.setDataMode(SPI_MODE1) ;
RTC_init(chipSelect, intFreq) ;
setTime(chipSelect, &TimeNow) ;
attachInterrupt(0, timeFunc, RISING) ;
/////////////////////////////////////// Begin Serial Communication /////////////////////////////////////////////////
Serial.begin(9600) ;
Serial1.begin(9600);
delay(10) ;
//////////////////////////////////////// Begin DS18B20 ////////////////////////////////////////////////////////////
sensors.begin();
//////////// Set The Resolution ///////
sensors.setResolution(ISOtank, 9);
//////////////////////////////////////////// RTC Run ////////////////////////////////////////////////////////////////////
int NewHour;
delay(1000) ;
readTime(chipSelect, &TimeNow) ;
////////////////////////////////////////////// Print Time to Serial Monitor /////////////////////////////////////////////////////
Serial.print("Time: ") ;
if(TimeNow.hh>12){
Serial.print(TimeNow.hh-12);
Serial.print(":") ;
if(TimeNow.mm < 10)
Serial.print("0");
Serial.print(TimeNow.mm) ;
Serial.print(":") ;
if(TimeNow.ss < 10)
Serial.print("0");
Serial.print(TimeNow.ss) ;
Serial.println(" P.M.");
else if(TimeNow.hh<12){
Serial.print(TimeNow.hh);
Serial.print(":");
if(TimeNow.mm < 10)
Serial.print("0");
Serial.print(":") ;
if(TimeNow.ss < 10)
Serial.print("0");
Serial.println(" A.M.");
else if(Serial.print(TimeNow.hh)){
Serial.print(":");
if(TimeNow.mm < 10)
Serial.print("0");
Serial.print(":") ;
if(TimeNow.ss < 10)
Serial.print("0");
Serial.print("Date: ") ;
Serial.print(TimeNow.m) ;
Serial.print("/") ;
Serial.print(TimeNow.d) ;
Serial.print("/") ;
Serial.println(TimeNow.y) ;
//Serial.print("Time Triggers: ") ;
//Serial.print(timeTrigs) ;
// timeTrigs = 0 ;
/////////////////////////////// Print Temperature to Serial Monitor //////////////////////////////////////////////////////////////////
delay(30);
Serial.print("Requesting temperature...");
Serial.print("Temperature is...");
Serial.print(sensors.getTempF(ISOtank));
Serial.println(" F");
/////////////////////////////////////////////////////////// Print Time to Nextion .///////////////////////////////////////////////////////
if(TimeNow.hh>12){
Serial1.print(F("TIME.txt=\""));
Serial1.print((TimeNow.hh)-12);
Serial1.print(F(":"));
if(TimeNow.mm < 10)
Serial1.print("0");
Serial1.print(TimeNow.mm);
if(TimeNow.ss < 10)
Serial1.print("0");
Serial1.print(TimeNow.ss);
Serial1.print(F(" P.M."));
Serial1.print(F("\""));
Serial1.print(F("\xFF\xFF\xFF"));
Serial1.print(TimeNow.hh);
if(TimeNow.mm < 10)
Serial1.print("0");
if(TimeNow.ss < 10)
Serial1.print("0");
Serial1.print(F(" A.M."));
else if(Serial1.print(F("TIME.txt=\""))){
if(TimeNow.mm < 10)
Serial1.print("0");
if(TimeNow.ss < 10)
Serial1.print("0");
Serial1.print(F("DATE.txt=\""));
Serial1.print(TimeNow.m);
Serial1.print(F("/"));
Serial1.print(TimeNow.d);
Serial1.print(TimeNow.y);
/////////////////////////////// Print Temp to Nextion ///////////////////////////////
Serial1.print(F("ISOtemp.txt=\""));
sensors.requestTemperatures();
Serial1.print(sensors.getTempF(ISOtank));
