Grand Central M4 Express Power Supply Selection Circuit
Aakash_Dey
Post by Aakash_Dey »
I have gone through the schematic for Grand Central M4 Express using SAMD51. I want to know the functionality of the USB CONNECTION & SELECTION and POWER SUPPLY SELECTION circuit.
USB Part_Grand Central M4 Schematic
USB Part_Grand Central M4.png (107.03 KiB) Viewed 360 times
I have measured the voltage as different points of this circuit at different conditions as attached in excel format.
USB Part_Grand Central M4 Test
USB Part_Grand Central M4 Test.png (29.77 KiB) Viewed 360 times
Could you please explain why the MOSFET (TR1) Based circuit is used and what is its functionality?
dastels
Re: Grand Central M4 Express Power Supply Selection Circuit
Post by dastels »
The purpose is to disconnect the USB's 5v from the board when the barrel connector is being used to power the board (and the power switch is "on").
Aakash_Dey
Ok, I understood. But, when Only USB is connected to the PC, the USB itself is powering to the whole circuit. Is the circuit functionality is correct in this case? Or else, the circuit should not be powered up when only USB is connected to the PC i.e. DC jack is not connected?
dastels
Post by dastels »
With Vin not present (no voltage from the barrel connector and/or the switch is off) to turn off the FET it conducts because there is 5v from the USB.
I think of it as a one-way door into a room. If Vin is in the room, it puts a chair under the doorknob to prevent anyone coming it. If Vin isn't there, there's no chair, and nothing to prevent someone (5v from USB) from pushing their way into the room.
Return to “Metro, Metro Express, and Grand Central Boards”
