MakeCode programming runs slow
by mlvc on Wed Jul 18, 2018 10:42 pm
I’m trying to program my cpx and crickit with the bumper bot code and I’m 3/4 thru the code and it’s just not running well. I try to add another block to the code and it’s staggers. I’m using the makercode APP from Adafruit.
I have a i7 7700k with 4.20ghz
Z270 MB
1080 GTX
16gb ram
I don’t think it’s my specs. Any suggestions?
mlvc
Re: MakeCode programming runs slow
by mlvc on Wed Jul 18, 2018 11:14 pm
Seems to run well from the web browser.
Anyone else have the same issue with the app?
mlvc
by Blueshark on Thu Jul 19, 2018 10:30 pm
@mlvc
Make Code IS a Web Based program, there's a tutorial to run Make Code in an Imulator for offline use but its not for beginners to install.
Also I've heard that Make Code works well on Internet Explorer (that's what I use), and it might have problems in Firefox internet browser's.
Cheers.
Blueshark
by Racer1Tn on Fri Aug 03, 2018 8:05 am
I built the Bumper Bot and the MakeCode tool freezes up. I tried running it in Firefox, it stalls when I get more code loaded. It seems to hang up when getting to the bumper bot on shake section. I downloaded the local app and it does the same thing. I've tried checking it in task manager and it does the same with it being the only program running. I've tried building the code in the tool as well as d/l and opening it, same result. Win 10 box with all current updates.
Guess I'll try it in Internet Exploder...
Racer1Tn
by adafruit2 on Tue Aug 07, 2018 4:48 pm
try Chrome, that works best we've found
adafruit2
Site Admin
by tballmsft on Tue Aug 07, 2018 5:25 pm
Just to be clear: is this a problem when you are using the Blocks editor and/or the JavaScript editor? We've had some issues with Blockly perf recently.
tballmsft
by TheFlave on Fri Aug 10, 2018 8:41 am
I was putting together some code last night in Block mode and I noticed a significant hit to performance after I added a healthy number of actions to the Windows version of MakeCode. I saw the last post in this thread and decided to load it up in JavaScript mode and the application runs a lot smoother now. There is definitely something causing performance issues in Block mode for the Windows thick client.
TheFlave
by adafruit2 on Fri Aug 10, 2018 10:48 am
yah i notice this too, w the microbit as well. tball try 10 blocks!
adafruit2
Site Admin
by tballmsft on Fri Aug 10, 2018 4:32 pm
Yes, this is a known problem (for Blockly) that we have been working with the Edge team on.
tballmsft
by daveo on Sun Sep 09, 2018 1:35 am
my students are having issues using the Windows app version with programs bigger than about 20 blocks (still pretty simple programs). Beyond that, it's too slow and laggy to really do much. If you save and import to browser-based version, no problem. The only reason we're using the app is to get access to the Console features (the only real way to debug with CPX). What is the ETA on getting this bug fixed? or adding Console functionality to the web version? Great product, but only usable for very simple programs at this point
daveo
