I am using the different coding languages and noticed makecode has problems even with the file only about 280K. Online makecode takes about 2 seconds to switch from javascript to blocks. On my windows 10 version the same code and switch take 15-20 seconds. In addition, clicking anything to edit takes a LONG time. The below code is as large as I can get on the PC app. Ideally, I would add yaw and x,y, z to make this a very effective glove controller. My pc is very powerful and fully loaded 6 core processor along with top end graphics card. I am going to try to add yaw and x, y, z online to see if Makecode can handle the code. Javascript seems to work better with no limitations so far. I will do CPython next.
Below is the MAX operating Block code I can put on the CPX.
let rollRight = 0
let left = 0
let forward = 0
let rollLeft = 0
let right = 0
let pitchForward = 0
let back = 0
let pitchBack = 0
let hold = 0
let direction = 0
let stopped = 0
// Set lights and roll/pitch variables with PV. Can be
// reset by shake, stops all rotation. pitchBack
input.onGesture(Gesture.TiltUp, function () {
if (direction == stopped) {
direction = back
pause(__internal.__timePicker(500))
if (direction == back) {
pitchForward = stopped
pitchBack = back
light.showRing(
`black black black red red red red black black black`
direction = stopped
// rollRight
input.onGesture(Gesture.TiltRight, function () {
direction = right
if (direction == right) {
rollLeft = stopped
rollRight = right
light.showRing(
`black black black black black red red red red red`
direction = stopped
// pitchForward
input.onGesture(Gesture.TiltDown, function () {
direction = forward
if (direction == forward) {
pitchForward = forward
pitchBack = stopped
light.showRing(
`red red black black black black black black red red`
direction = stopped
// Shake resets variables to start
input.onGesture(Gesture.Shake, function () {
direction = hold
pitchBack = stopped
rollLeft = stopped
rollRight = stopped
light.showAnimation(light.rainbowAnimation, __internal.__timePicker(500))
light.clear()
direction = stopped
// rollLeft
input.onGesture(Gesture.TiltLeft, function () {
direction = left
if (direction == left) {
rollRight = stopped
rollLeft = left
light.showRing(
`red red red red red black black black black black`
direction = stopped
// Initial Start Values
stopped = 0
hold = 99
direction = hold
back = 1
forward = 2
left = 3
right = 4
pitchBack = stopped
rollLeft = stopped
rollRight = stopped
light.clear()
direction = stopped
Makecode for CPX windows 10 app very slow
- genus1
Re: Makecode for CPX windows 10 app very slow
I would like to know if support has noticed limitations with the PC version of the Makecode editor.
[moved to the MakeCode forum]
- genus1
I would still like to know if support has noticed size edit limitations with the PC version of the Makecode editor.
- liudr
I have the same issues with switching between Javascript and MakeCode. I have a moderate PC but that should more than able to handle such simple task but it would freeze during switching, not to mention it stops uploading code after only a handful of successful uploads per software+hardware restart/unplug.
- danhalbert
You might try other browsers, to see if it's faster. MakeCode slowness on large programs is an issue known to the MakeCode folks at MicroSoft.
