Makecode will not load on CPX
by vincelewski on Tue May 14, 2019 10:04 am
Whenever I drop (or copy/paste) the UF2 file downloaded from the makecode site into CPLAYBOOT, the file loads, the board is ejected, and the same thing happens every time. No matter if I use a different browser, try a simple file (compiled blink sketch), or any number of combinations I get the same result (see picture) Blue and red lights, with 0 interactivity.
vincelewski
Re: Makecode will not load on CPX
by vincelewski on Tue May 14, 2019 10:56 am
So I figured out how to get to work, but it requires me to unplug the board from usb power, and plug in battery power for the sketch to run on the board...is this correct? shouldn't it also run when plugged in? am I using the wrong type of cable? the cable seems to work in all other instances so...
vincelewski
by adafruit_support_carter on Tue May 14, 2019 11:18 am
It should work OK with USB power. Can you share your MakeCode project and put the link here.
by vincelewski on Wed May 15, 2019 3:00 am
vincelewski
by adafruit_support_carter on Wed May 15, 2019 11:51 am
That worked OK for me while still attached to the computer via USB cable. I went to your link, clicked edit so I could open it. Then clicked download and saved the UF2 to my computer. Then put the CPX in bootloader mode and copied UF2 to CPLAYBOOT. It ejected and was dark. But I can press the buttons and get the NeoPixels to light up and if I shake it more NeoPixels.
When you are in bootloader mode, what are the contents of the INFO_UF2.TXT file in the CPLAYBOOT folder?
What version of MakeCode are you running? (Gear icon -> About...)
by vincelewski on Thu May 16, 2019 4:50 am
Screenshot 2019-05-16 at 10.47.44.png (18.73 KiB) Viewed 196 times
I'm using the same version of makecode that you posted a photo of in your reply.
vincelewski
by adafruit_support_carter on Thu May 16, 2019 11:16 am
It looks like you did the bootloader update from here?
https://learn.adafruit.com/adafruit-cir ... bootloader
What operating system are you using?
by vincelewski on Fri May 17, 2019 3:00 am
I believe I did update the bootloader from that page. I'm using MacOS Mojave 10.14.4.
vincelewski
by adafruit_support_carter on Fri May 17, 2019 11:54 am
I wonder if you're still running into some of the quirks related to that same issue with MacOS 10.14.4. The bootloader update should have fixed it. And you have done that based on the info in your INFO_UF2.TXT file. But maybe it is still lingering for some reason.
It's not totally dead, right? It can take a new program. But you have to switch to battery power to actually have the program run?
by vincelewski on Wed May 22, 2019 4:24 am
Correct. But only for Makecode. When uploading files from the Arduino IDE or utilizing Circuitpython, the code runs immediately after uploading over USB.
vincelewski
by adafruit_support_carter on Wed May 22, 2019 12:52 pm
Really odd behavior. Do you have access to another computer you could use to test the MakeCode behavior?
