Can't IF Compare a Variable to a Variable?
by mnopneal on Sun Apr 18, 2021 4:02 pm
Working with the Buckaroo plant water device bolted to Micro:bit.
I really wanted to make the Threshold a variable, which was adjusted up/down with A/B buttons.
BUT, the IF statement appears to only support comparing a variable to a fixed number. Not another variable.
And I can't seem to find how to set a variable = another variable - still another variable.
What AM I missing?
regards,
Neal
mnopneal
Re: Can't IF Compare a Variable to a Variable?
by dastels on Sun Apr 18, 2021 10:34 pm
Any two things can be compared as long as they are similar enough types.
Can you post your code, it sounds like something is a little off.
dastels
by mnopneal on Mon Apr 19, 2021 3:24 pm
Thanks for the reply. It looks like if the IF block already compares "Reading" < 950, then you can't just type in another variable name instead.
Rather you have to pick the variable, and then drag it.
mnopneal
by dastels on Mon Apr 19, 2021 4:16 pm
AH Makecode.. missed that. You should be able to drag the desired variable to replace the constant.
dastels
by johnpark on Thu Apr 22, 2021 6:31 pm
yes, you can drag the variables from the VARIABLES category into the comparison block. https://makecode.com/_8gbADXa0uAXt
johnpark
