Using blocks to program LED's?
by Mathpun on Mon Feb 19, 2018 1:41 pm
Hello, I have a couple of questions regarding things I can create in makecode:
I am using a circuit playground express, and can get things working the traditional way in Arduino studio but would like to do it makecode so I can show kids how its done!
1. I have a "Adafruit Mini 8x8 LED Matrix w/I2C Backpack - Red" and I was wondering how I could get this to work using makecode?
2. If I want to use a sensor not built into the playground, is that possible in makecode as well? Like the UV sensor or the color detector sensor.
3. What about neopixels that are not in a strip -- (Flora RGB Smart NeoPixel version 2 - Pack of 4 PRODUCT ID: 1260), I have them connected but cannot figure it out in makecode.
4. Will makecode be supporting a gemma, or flora anytime soon?
Thank you so much!!
Mathpun
Re: Using blocks to program LED's?
by adafruit_support_carter on Mon Feb 19, 2018 3:10 pm
Same answer for both of these. There would need to be support for the hardware in makecode. I don't think there currently are any for these products.
In general, all NeoPixels are in a strip. Even if the product shape isn't strip-like. To use NeoPixels that you've attached, you'd want to use the block NEOPIXEL -> "create strip on Ax with N pixels", and replace Ax with the analog pin you've attached to and N with the number of pixels.
Adding more boards is something that will be considered, but not on any kind of guaranteed release schedule.
by Mathpun on Mon Feb 19, 2018 4:18 pm
Thank you for your answers.
So for Q1 and 2, could I use this to try and build something that could accommodate it or no?
https://makecode.adafruit.com/packages
Mathpun
by adafruit_support_carter on Mon Feb 19, 2018 4:24 pm
Yep, I think that's the general way to go.
by pelikhan on Thu Jun 07, 2018 1:30 am
For gemma, you can try https://maker.makecode.com
pelikhan
