BIT Banging serial from CPX
by bhedrick on Mon Apr 16, 2018 1:56 pm
Has anyone had any luck getting CPX to talk serial to another device?
I have used both a scope and a Saleae Logic to try to get things working. What I am finding is that the timing of code executing doesn't seem to be consistent and as a result the baud rate can end up varying enough that the highs and lows are detected properly either leading to incorrect values/letters or framing errors.
Here's the project: https://makecode.com/_Ak7FePYy7cwL
Here's my Makecode function. Notice I have removed loops in an effort to try to figure out if I can address the timing issue. The code is implemented using MSB for data transfer.
function sendSerialText2() {
    messageToSend = "Goodbye My Friend!"
    numChars = messageToSend.length
    currChar = 0
    for (let index7 = 0; index7 <= numChars - 1; index7++) {
        currChar = messageToSend.charCodeAt(index7)
        pins.A6.digitalWrite(false)
        control.waitMicros(94)
        if (currChar & 128) {
            pins.A6.digitalWrite(true)
        } else {
        if (currChar & 64) {
        } else {
        if (currChar & 32) {
        } else {
        if (currChar & 16) {
        } else {
        if (currChar & 8) {
        } else {
        if (currChar & 4) {
        } else {
        if (currChar & 2) {
        } else {
        if (currChar & 1) {
        } else {
bhedrick
Re: BIT Banging serial from CPX
by bhedrick on Tue Apr 17, 2018 8:30 pm
While I don't have a solution for this issue, the project I am working on found a work-around, for now. We added an Arduino Micro in the middle. The goal was to talk to an LCD via an I2C backpack. With our short timeframes, we don't have time to implement something like the I2C LCD library from Adafruit in MakeCode.
Originally plan
CPX -> via serial just sending letters -> Arduino Micro -> serial -> serial backpack -> LCD
The workaround is
CPX -> via I2C just sending letters -> Arduino Micro -> via serial repeating letters -> Arduino Micro -> serial -> serial backpack -> LCD
We are aiming for
CPX -> via I2C just sending letters -> Arduino Micro (master and slave) -> serial -> serial backpack -> LCD
bhedrick
