Huzza ESP8266 WiFi modul & MakeCode Blockcode?
by marc_is_curious on Sun May 20, 2018 4:50 am
I would like to ask you for advice on behalf of the inquiries as listed below –
any hint, link or idea is higly appreciated!
_________________________________________________________________________________________
Adafruit’s “Huzzah” ESP8266 WiFi module +
Microsoft MakeCode Blockcode online
How can I use the “HUZZAH ESP8266 breakout board”* with Microsoft MakeCode Blocks?
*https://www.adafruit.com/product/2471
I tried to modify “elecfreaks”’environment tutorial** but could not find any feedback on WiFi activity (please see below: 3a & following)
**https://www.elecfreaks.com/12224.html
Code Please see image attached below or online: http://www.directupload.net/file/d/5093/z9lr9sit_jpg.htm
Wiring Please see image attached below or online: http://www.directupload.net/file/d/5093/napl6tc3_jpg.htm
No WiFi activity but esp8266 activity
No WiFi connection indicated
I checked activity via …
- Thingspeak, Desktop/Laptop computer, (Telekom) Router, Serial Terminal program(s)
ESP8266 activity
flickering LED lights on esp8266 “adafruit huzzah” module
- red & blue (close to printed antenna)
To solve the problems: Should i …
… load “elecfreaks” firmware for their ESP8266 Wifi module onto Adafruit ESP8266 Huzzah?
“Resources” / “Source Code”: https://www.elecfreaks.com/estore/esp8266-serial-wifi-module.html
… change elecfreaks esp8266 library (address for “thingspeak”’s api Code*):
184.106.153.149 instead of api.thingspeak.com?
*https://makecode.microbit.org / javascript-explorer / ESP8266_IoT / ESP8266.ts / function connectthingspeak
… How can i modify the address (the file* holding the address is locked)?
… change the Passwords’ Entries?
“Key” = WLAN-Key or …
- password router?
- personal password?
… change the ESP8266 module’s wiring whilst uploading the code to the micro:bit board?
e.g.
- connect ESP8266’s “reset” pin to 3.3V ?
- disconnect ESP8266’s “enable” pin from 3.3V ?
I look forward to hearing from you,
best Regards
Marc
Wiring
B-Wiring .jpg (470.86 KiB) Viewed 190 times
Code
A-Code .jpg (219.4 KiB) Viewed 190 times
marc_is_curious
