I set up a button on the Crikit as shown on this page:
https://learn.adafruit.com/adafruit-cr ... e-signals
However, even when the button is not pressed (open), the digital signal intermittently will return a true signal. If the button is pressed (closed), the signal will always return a true signal to the makecode, so that is working.
I've attached my Makecode program for reference.
Thanks for the help
Micro:bit Crickit Signal IO issues
Re: Micro:bit Crickit Signal IO issues
Post a photo showing your hardware and connections please. Schematics only show how things are supposed to be, and rarely include the things that actually cause problems.
800x600 images usually work best.
- jhajel
Here is a video of the set up with unexpected behavior.
https://www.youtube.com/watch?v=aGdGY7yJ-V4
Also, I am uploading the exact MakeCode program that is shown in the video.
- jhajel
Ok, I think I fixed this by adding a pull-down (I think) resistor as shown here:
https://learn.adafruit.com/crickit-and- ... o/overview.
However, it states that the Crickit has a internal pull-up resistor, but when I hooked up with just a connection between the signal and ground, I got a floating input.
"All pins can have an internal ~50Kohm pull-up resistor set when used as an input"
Here: https://learn.adafruit.com/adafruit-cri ... ickit-tour
JMH
(Note: my knowledge of electrical circuits is pretty minimal)
JMH
Just to check, did you set the pins using the INPUT_PULLUP identifier? That's what tells the Crickit's microcontroller to connect the built-in pull-up resistors.
- jhajel
I am using MakeCode. Is there such a command with the MakeCode programming?
I'm afraid I'll need to pass that over to the MakeCode forum.
- jhajel
I am trying to use the Signal IO with a pullup resistor on Crickit, but I do not see a command to do that.
Can anyone help?
Can anyone help?
