I have been trying a simple play tone sketch on maker.makecode with a Feather M0 Express.
I get a lot of other stuff to work (on button press, light blinking, IR sensor), but when I try even the simplest example from their tutorial using a piezo connected ti A0 and GND, all I get is a single high pitched tone that does not stop. If tries multiple tones with "rests" in between, different feathers, different piezos--same result.
I've also tries similar arduino code with the same hardware, and that works as expected, as does the web simulator.
My hypothesis is that the maker.makecode play tone function does not work for the Feather M0 Express. Has anyone tried or heard any thing about this?
Here's a screen shot of a very simple example that behaves as described above (yes I know it's play sound, but play tone has the exact same problem).
Feather M0 Express Maker.MakeCode Tone (not)
- Virgil_Machine
- johnpark
Re: Feather M0 Express Maker.MakeCode Tone (not)
I got the same response -- no audio. I'm adding this to an existing bug report for Trinket M0, as it may be related. https://github.com/microsoft/pxt-maker/issues/234
- Virgil_Machine
Thank you. FYI--I just tried it with a Metro M0 Express with the same result. Does indeed sound like a bug.
I cross-posted on the maker.makecode forum. No response yet.
