Error "operator '==' cannot be applied to types 'false'"
by Mathpun on Sat Feb 15, 2020 2:48 pm
hello -- I am trying to use my CPX in makecode to just display the color it detects by the color sensor -- I am going off this example and tweaking it: https://makecode.adafruit.com/73435-24525-19966-55549 From this project: https://learn.adafruit.com/florabrella/ ... playground
SO I am copying the portion that just uses the color sensor and getting this error --
"Error "operator '==' cannot be applied to types 'false' or 'true'"" (see image attached) OR see my actual code here:
https://makecode.com/_4d1P79DKAUEf
CAN anyone help me figure out how to do this in makecode? What about if I wanted to add some neoxpixels? Just the single one that you can sew on (https://www.adafruit.com/product/1260)
LMK thanks so much!
Screen Shot 2020-02-15 at 10.46.50 AM.png (157.58 KiB) Viewed 103 times
Mathpun
Re: Error "operator '==' cannot be applied to types 'false'"
by V2man on Sat Feb 15, 2020 8:12 pm
Right click on true Boolean block in the set colorsense block. to get help on BOOLEAN.
Right click on the cyan color of the if block to get help on the CONDITIONAL block. Unfortunately, the help documentation does not have an example of a Boolean Conditional! See the method below.
Here's a micro:bit guide. It's useful. https://makecode.microbit.org/blocks/logic
CPX-Boolean_Conditional.uf2
(282 KiB) Downloaded 4 times
V2man
by V2man on Sat Feb 15, 2020 11:48 pm
Misspelling: colosense should be colorsense.
Conditional block is just looking for a Boolean answer of true or false. Should I execute the next steps or skip.
In your code Makecode is complaining that you did not define the Boolean variable colorsense and rainbow. Once you do define colorsense as true or false the conditional statement will be happy as shown below. However the strip block is looking for 3 numbers, (98, 54, 175). You cannot assign a Boolean variable to a number variable in your code example. This guide discusses colors https://learn.adafruit.com/fancyled-library-for-circuitpython/colors
V2man
