Makecode program crashes when rotating an image
by ractive on Sat Apr 25, 2020 3:49 pm
Dear PyGamer users
Rotating any image by 90 or 270 degrees let the MakeCode arcade game crash on the PyGamer. This very simple MakeCode arcade program crashes with the error code 821 when executed on the PyGamer (while it successfully runs in the simulator):
img`1`.rotated(90);
I'm not sure if this is an issue with MakeCode arcade or with the PyGamer. Any clues where to do a proper error report?
ractive
Re: Makecode program crashes when rotating an image
by ractive on Sat Apr 25, 2020 4:27 pm
Actually the call to image.transpose fails: img`1`.transpose()
As a workaround, use these functions here:
function transpose(img: Image): Image {
    const result = image.create(img.height, img.width);
    for(let x = 0; x < img.width; x++) {
        for (let y = 0; y < img.height; y++) {
            result.setPixel(y, x, img.getPixel(x, y));
    return result;
function rotate(img: Image, deg: number): Image {
    if (deg == -90 || deg == 270) {
        const r = transpose(img);
        r.flipY();
        return r;
    } else if (deg == 180 || deg == -180) {
        const r = i.clone();
        r.flipX();
        r.flipY();
        return r;
    } else if (deg == 90) {
        const r = transpose(i);
        r.flipX();
        return r;
    } else {
        return i;
ractive
by johnpark on Thu Apr 30, 2020 10:02 pm
Interesting. Could you share the original code you were using that was crashing?
johnpark
by ractive on Sun May 03, 2020 3:15 pm
Hi John
This super simple program crashes on my PyGamer with code 821:
https://makecode.com/_JkFch21Mp3AW
Best regards,
James
ractive
