Inconsistent NeoPixel Jewel behavior on CircuitPlayground an
by balesse on Thu Jun 18, 2020 11:53 am
Are the 7 pixel Jewels compatible with MakeCode? I can get the leds on the jewel to light up but behavior is odd. I'm rotating between Blue, White, Yellow, and Pink. The lights on the CircuitPlayground work fine, but on the Jewel, two of the pixels work fine, three of them change different colors, one of them flashes between green and off, and the last one never turns on. I've tried two different Jewels and neither of them works correctly.
Any ideas for me?
Here is my code:
let strip = light.createStrip(pins.A1, 7)
forever(function () {
    light.setAll(0x0000ff)
    pause(1000)
    light.setAll(0xff9da5)
    pause(1000)
    light.setAll(0xff8000)
    pause(1000)
    light.setAll(0xff0080)
    pause(1000)
    strip.setAll(0x0000ff)
    pause(1000)
    strip.setAll(0xff9da5)
    pause(1000)
    strip.setAll(0xff8000)
    pause(1000)
    strip.setAll(0xff0080)
    pause(1000)
Thanks in advance for the help!
balesse
Re: Inconsistent NeoPixel Jewel behavior on CircuitPlaygroun
by adafruit_support_bill on Thu Jun 18, 2020 12:02 pm
Did you purchase the RGB or RGBW version of the jewels?
by balesse on Thu Jun 18, 2020 12:05 pm
RGBW version. Do they operate differently? I thought it was just that the colors would be a bit different from the two.
balesse
by adafruit_support_bill on Thu Jun 18, 2020 12:10 pm
The RGBW version has a 4th channel, so you need to send 4 bytes per pixel rather than 3. You need to specify this when you define the strip in your code. I'm not sure if MakeCode supports RGBW yet. I'll check with our MakeCode expert.
by johnpark on Thu Jun 18, 2020 1:50 pm
Hi -- yes, you can use RGBW NeoPixels in MakeCode -- Head to Light > NeoPixel category of blocks and down at the very bottom there's a block called "set strip mode to RGB (GRB format)". Bring that into your start block and change the dropdown to RGB+W
johnpark
by balesse on Thu Jun 18, 2020 3:25 pm
Yes, thanks, just found that as well. I just needed to set the newpixel mode.
let strip = light.createStrip(pins.A1, 7, NeoPixelMode.RGBW)
It is working great now.
Thanks for the help!
balesse
