Re: Unable to download to PYGAMER
adafruit_support_carter wrote:Was your previous success with using this same PC?
adafruit_support_carter wrote:Thanks for all the additional information. Good to know the PyGamer at least works.
I'm seeing the same thing, with Firefox 81.0.2. I followed the link to your code, changed hardware to PyGamer, and downloaded the UF2. It does not run.
I am seeing errors in the Web Console though. So it may be related to that. See if you can see the same on your end and supply that information back to this thread:
https://forum.makecode.com/t/cannot-dow ... er/3955/24
This seems like it's more of a MakeCode issue than a PyGamer issue. So the help in that forum is the place to go.
If the PyGamer accelerometer is shaked or tapped, it will play a 'coin' sound from the speaker or headphones if they are plugged in
cosmoscowboy wrote:I just wanted to check whether this is normal behavior. When I plug it in to the computer I see the bootloader screen. If I pull out the usb cable, it stays on. When I press the reset button once, the screen goes black and the lights at the front are all red. When I switch it back on, the screen is still black and the lights are still red. Pressing the reset button one/twice while it is still on does nothing. The red light at the back is flashing. While it is still on, it is only when I plug the usb cable back in that I see the bootloader screen. Removing the usb cable again, the bootloader is still visible. Turning it off/on, same problem as before (blank screen, all lights at front are red).
adafruit_support_carter wrote:That sounds like a USB cable issue. Make sure it's not a charge only cable. But also, try other USB cables that you know are data capable.
