FFT in MakeCode
FFT in MakeCode
by flounder on Wed Oct 28, 2020 2:50 pm
I had a simple idea for a Halloween project. It involves using a Circuit Playground Express, getting input from its microphone, doing an FFT, and taking some actions.
You would think this would be easy.
I can't figure out how to do it.
I tried using the "use the microphone" code from https://learn.adafruit.com/circuit-play ... microphone, but it fails to compile for what I can best determine are deep failures in the header files. I have reported this already in the CPE forum. I tried to trace what was going on, but the Arduino IDE environment is essentially hostile to this kind of analysis.
So, I thought, I will try CircuitPython. No luck there, either. The examples are overly elaborate, require a Clue, which is not what I want to use for this project, and provide no stripped down example equivalent to the microphone example. My need is simple: read a half-second of sound, do an FFT, do something with that, repeat.
Well, OK, what about MakeCode. Surely there is a way, using MakeCode, to do something this simple. Not as far as I can tell. Again, nothing that shows how to do something simple on a CPE. I don't care if it can be done on a Teensy, or a Clue; I care that I can get a piece of code that runs, possibly poorly, on any MakeCode device, and does exactly one thing: reads a sample sound and does an FFT. Nothing else. Trying to strip out all the stuff I don't need should not be necessary.
So where do I go to get a simple program that actually compiles and runs, in C++, CircuitPython, or MakeCode, and does nothing more elaborate than what I have described.
flounder
Re: FFT in MakeCode
by kevinjwalters on Wed Oct 28, 2020 9:35 pm
There's some code in https://github.com/adafruit/Adafruit_Ze ... r/examples but perhaps it's similar to what you've already tried?
kevinjwalters
