proximity sensor
Microsoft's MakeCode platform for easy blocks-style programming
Gstvgrc
proximity sensor
Post by Gstvgrc »
Hi everyone. I'm a newbie with CPX: Trying to use the Infrared receiver / transmitter as a proximity sensor but can't find tutorials for MakeCode:
"... By bouncing IR light off of items and reading the reflected light, you can also do very simple proximity sensing!" ...
and
"... There's also a secret capability, you can read the 'raw' analog value from the receiver LED diode to do basic IR proximity sensing. The direct analog value is available from pin A10..."
Any ideas? thanks
johnpark
Re: proximity sensor
Post by johnpark »
Unfortunately, using IR as proximity sensing isn't exposed in MakeCode (that description in the CPX main page you quoted applies to CircuitPython and Arduino). However, you can use the light level block in MakeCode to do something roughly similar.
Gstvgrc
Post by Gstvgrc »
Thanks for your time
Return to “MakeCode”
