MakeCode Tutorial In GitHub
Microsoft's MakeCode platform for easy blocks-style programming
dd9dd8c
Post by dd9dd8c »
How can I publish a Adafruit MakeCode tutorial though GitHub? I've tried the method mentioned in the MakeCode documentation.
https://makecode.microbit.org/#tutorial:https://github.com/myorg/myrepo
But, I always get the error, "Please check your internet access and ensure the tutorial is valid. Network request failed". Below are the two URLs I've tried.
https://makecode.adafruit.com/#tutorial:https://github.com/hikerguy1900/Circuit_Playground
https://makecode.adafruit.com/#tutorial ... Playground
I've also tried using the raw line to the GitHub file.
https://makecode.adafruit.com/#tutorial:https://raw.githubusercontent.com/hikerguy1900/Circuit_Playground
My plan is to create several tutorials. Managing them as web projects in Adafruit MakeCode would be tedious.
dd9dd8c
Re: MakeCode Tutorial In GitHub
Post by dd9dd8c »
I figured out a way to do it. First, it seems that more than the README.md file is needed. Getting the full source for a project in to GitHub was the next challenge. The only way I could find to do this was using a Beta version of MakeCode that was mentioned in a December 2019 Adafruit blog post.
https://blog.adafruit.com/2019/12/18/us ... de-github/
Using that Beta version I was able to use the new GitHub button next to the save button to save the full project in to GitHub. Then the GitHub URL for the tutorial began to work.
https://github.com/hikerguy1900/Circuit ... Blinky.git
Return to “MakeCode”
