MLX90640_arcadaCam example code
Microsoft's MakeCode platform for easy blocks-style programming
Minshan
Post by Minshan »
I want to use Arduino to drive my thermal camera(MLX90640). Then,I open the example “Adafruit MLX90640-MLX90640_arcadaCam.” However, it can’t work. It said “Adafruit_Arcada does not name a type.“ But I have installed the libraries ”Adafruit Arcada”. (The attachment is the picture showing which I installed.) What’s wrong with it? Could you help me solve this problem? Thanks!
wrong mwssage:
MLX90640_arcadaCam:3:1: error: 'Adafruit_Arcada_Library' does not name a type
Adafruit_Arcada_Library arcada;
#include <Adafruit_MLX90640.h>
#include <Adafruit_Arcada.h>
Adafruit_Arcada arcada;
Adafruit_MLX90640 mlx;
float frame[32*24]; // buffer for full frame of temperatures
//low range of the sensor (this will be blue on the screen)
#define MINTEMP 20
//high range of the sensor (this will be red on the screen)
#define MAXTEMP 35
//the colors we will be using
const uint16_t camColors[] = {0x480F,
0x400F,0x400F,0x400F,0x4010,0x3810,0x3810,0x3810,0x3810,0x3010,0x3010,
0x3010,0x2810,0x2810,0x2810,0x2810,0x2010,0x2010,0x2010,0x1810,0x1810,
0x1811,0x1811,0x1011,0x1011,0x1011,0x0811,0x0811,0x0811,0x0011,0x0011,
0x0011,0x0011,0x0011,0x0031,0x0031,0x0051,0x0072,0x0072,0x0092,0x00B2,
0x00B2,0x00D2,0x00F2,0x00F2,0x0112,0x0132,0x0152,0x0152,0x0172,0x0192,
0x0192,0x01B2,0x01D2,0x01F3,0x01F3,0x0213,0x0233,0x0253,0x0253,0x0273,
0x0293,0x02B3,0x02D3,0x02D3,0x02F3,0x0313,0x0333,0x0333,0x0353,0x0373,
0x0394,0x03B4,0x03D4,0x03D4,0x03F4,0x0414,0x0434,0x0454,0x0474,0x0474,
0x0494,0x04B4,0x04D4,0x04F4,0x0514,0x0534,0x0534,0x0554,0x0554,0x0574,
0x0574,0x0573,0x0573,0x0573,0x0572,0x0572,0x0572,0x0571,0x0591,0x0591,
0x0590,0x0590,0x058F,0x058F,0x058F,0x058E,0x05AE,0x05AE,0x05AD,0x05AD,
0x05AD,0x05AC,0x05AC,0x05AB,0x05CB,0x05CB,0x05CA,0x05CA,0x05CA,0x05C9,
0x05C9,0x05C8,0x05E8,0x05E8,0x05E7,0x05E7,0x05E6,0x05E6,0x05E6,0x05E5,
0x05E5,0x0604,0x0604,0x0604,0x0603,0x0603,0x0602,0x0602,0x0601,0x0621,
0x0621,0x0620,0x0620,0x0620,0x0620,0x0E20,0x0E20,0x0E40,0x1640,0x1640,
0x1E40,0x1E40,0x2640,0x2640,0x2E40,0x2E60,0x3660,0x3660,0x3E60,0x3E60,
0x3E60,0x4660,0x4660,0x4E60,0x4E80,0x5680,0x5680,0x5E80,0x5E80,0x6680,
0x6680,0x6E80,0x6EA0,0x76A0,0x76A0,0x7EA0,0x7EA0,0x86A0,0x86A0,0x8EA0,
0x8EC0,0x96C0,0x96C0,0x9EC0,0x9EC0,0xA6C0,0xAEC0,0xAEC0,0xB6E0,0xB6E0,
0xBEE0,0xBEE0,0xC6E0,0xC6E0,0xCEE0,0xCEE0,0xD6E0,0xD700,0xDF00,0xDEE0,
0xDEC0,0xDEA0,0xDE80,0xDE80,0xE660,0xE640,0xE620,0xE600,0xE5E0,0xE5C0,
0xE5A0,0xE580,0xE560,0xE540,0xE520,0xE500,0xE4E0,0xE4C0,0xE4A0,0xE480,
0xE460,0xEC40,0xEC20,0xEC00,0xEBE0,0xEBC0,0xEBA0,0xEB80,0xEB60,0xEB40,
0xEB20,0xEB00,0xEAE0,0xEAC0,0xEAA0,0xEA80,0xEA60,0xEA40,0xF220,0xF200,
0xF1E0,0xF1C0,0xF1A0,0xF180,0xF160,0xF140,0xF100,0xF0E0,0xF0C0,0xF0A0,
0xF080,0xF060,0xF040,0xF020,0xF800,};
uint16_t displayPixelWidth, displayPixelHeight;
  if (!arcada.arcadaBegin()) {
    Serial.print("Failed to begin");
    while (1);
  arcada.displayBegin();
  // Turn on backlight
  arcada.setBacklight(255);
  Serial.begin(115200);
  //while (!Serial);
  arcada.display->fillScreen(ARCADA_BLACK);
  displayPixelWidth = arcada.display->width() / 32;
  displayPixelHeight = arcada.display->width() / 32; //Keep pixels square
  delay(100);
  Serial.println("Adafruit MLX90640 Camera");
  if (! mlx.begin(MLX90640_I2CADDR_DEFAULT, &Wire)) {
    arcada.haltBox("MLX90640 not found!");
  Serial.println("Found Adafruit MLX90640");
  Serial.print("Serial number: ");
  Serial.print(mlx.serialNumber[0], HEX);
  Serial.print(mlx.serialNumber[1], HEX);
  Serial.println(mlx.serialNumber[2], HEX);
  mlx.setMode(MLX90640_CHESS);
  mlx.setResolution(MLX90640_ADC_18BIT);
  mlx.setRefreshRate(MLX90640_8_HZ);
  Wire.setClock(1000000); // max 1 MHz
  uint32_t timestamp = millis();
  if (mlx.getFrame(frame) != 0) {
    Serial.println("Failed");
    return;
  int colorTemp;
  for (uint8_t h=0; h<24; h++) {
    for (uint8_t w=0; w<32; w++) {
      float t = frame[h*32 + w];
      // Serial.print(t, 1); Serial.print(", ");
      t = min(t, MAXTEMP);
      t = max(t, MINTEMP);
      uint8_t colorIndex = map(t, MINTEMP, MAXTEMP, 0, 255);
      colorIndex = constrain(colorIndex, 0, 255);
      //draw the pixels!
      arcada.display->fillRect(displayPixelWidth * w, displayPixelHeight * h,
                               displayPixelHeight, displayPixelWidth,
                               camColors[colorIndex]);
  Serial.print((millis()-timestamp) / 2); Serial.println(" ms per frame (2 frames per display)");
  Serial.print(2000.0 / (millis()-timestamp)); Serial.println(" FPS (2 frames per display)");
arcada library.png (22.08 KiB) Viewed 856 times
Last edited by adafruit_support_carter on Wed Dec 09, 2020 3:46 pm, edited 1 time in total.
Reason: fix [code] tag
Disciple
Re: MLX90640_arcadaCam example code
Post by Disciple »
Which microcontroller are you using? Is it included on Adafruit's list of compatible boards?
I'm just another customer, but I did get a MLX90640 project to work.
Hallelujah!
Disciple
Yep, good question. What Arduino board do you have?
Minshan
Post by Minshan »
I use MLX90640
That's the sensor breakout. What are you attaching the MLX90640 to?
Minshan
Post by Minshan »
ESP32(NodeMCU-32S)
adafruit2
Post by adafruit2 »
yeah arcada is for our boards that have screens built in - you will have to adapt the code to your display and display driver. maybe folks online have done something for you to use
Minshan
Post by Minshan »
Disciple wrote:Which microcontroller are you using? Is it included on Adafruit's list of compatible boards?
Hallelujah!
Disciple
Thanks for your reply. Can I ask you some questions?
Did you encounter the same problem? And how did you adjust your code?
I did a test compile of the example against that target board and I did get the same error that you did.
The solution is not simple. You would need to adapt code written for a specific set of hardware to your setup.
The Arcada library is really only for use with the boards defined here:
https://github.com/adafruit/Adafruit_Ar ... ter/Boards
Minshan
Post by Minshan »
adafruit2 wrote:yeah arcada is for our boards that have screens built in - you will have to adapt the code to your display and display driver. maybe folks online have done something for you to use
Can you give me the thorough information of this board? Also the website where I can buy it. Thanks.
The previously linked list of header files is the best source:
The board names come after the Adafruit_Arcada_ prefix. You should be able to use that name to search and quickly get to a specific product page. More than one board exists. They are available in the Adafruit shop:
https://www.adafruit.com/
Disciple
Post by Disciple »
Minshan wrote:Thanks for your reply. Can I ask you some questions?
My MLX90640 project was developed using the Arcada library on an Adafruit PyBadge.
(The same setup ran the MLX90640_arcadaCam example.)
It was initially created on a Teensy 3.2 using code from SparkFun. It required libraries for managing I2C, SPI, ST7735R displays, MicroSD readers, and Adafruit_GFX. That sort of structure might be needed to recreate an arcadaCam clone using another processor, a fair task. Switching to a PyBadge would be much simpler. As you see fit. Hope this helps.
Hallelujah!
Disciple
Return to “MakeCode”
