Cricket, Microbit, MakeCode
by keithbraafladt on Thu Dec 17, 2020 11:37 am
I have a Cricket for the Microbit - I'm excited to use it with servos I also teach with it and would like to use it with MakeCode but I am confused about if it does not work or if it does. I found this that says it does not:
https://learn.adafruit.com/adafruit-cri ... t/makecode
I found this page that provides code... so which is it and if not when might it be available and what do you recommend until then?
https://learn.adafruit.com/microbit-cri ... t/the-code
keithbraafladt
Re: Cricket, Microbit, MakeCode
by dastels on Thu Dec 17, 2020 11:52 am
As that first page says it's "not currently available", although it has been previously. I have no idea if it will be again.
dastels
by nickine9 on Fri Dec 18, 2020 8:23 am
i have been using https://makecode.microbit.org/beta#editor as you can see from the link it is a beta and i don't know when or how it is put into production.
the adafruit guide for the crickit has the link for the extension you need to use it.
hope that helps
nick
nickine9
by RRWagner on Fri Mar 26, 2021 11:35 pm
I purchased the Crickit based on this page,
https://www.adafruit.com/product/3928
that says, "Please note at this time that MicroPython is not supported yet, just MakeCode & Arduino!"
Which to me says that it works with MakeCode on the product as listed: Crickit for the microbit.
But now that I have it, on this page:
it says, "MakeCode is currently not available for Crickit for micro:bit or the Crickit HAT for Raspberry Pi."
and, "a binary from MakeCode it is compiled for the Circuit Playground Express"
Can someone from adafruit give us a clear response on this?
Thank you
RRWagner
by dastels on Sat Mar 27, 2021 10:35 am
I advise you to make a new thread for this, as it will have a better change of being seen and answered by everyone (i.e. someone who might have an answer for you... which, alas, I don't).
dastels
by johnpark on Mon Mar 29, 2021 8:12 pm
You can use MakeCode on the micro:bit with Crickit. In makecode.microbit.ort/#editor click on Advanced > Extensions then in the Extensions window type "crickit" into the search field and press enter. You'll see the crickit extension show up, just click on it to add.
johnpark
