CPX: Random number generator not random
Microsoft's MakeCode platform for easy blocks-style programming
smagoun
Post by smagoun »
The random number generator for the Circuit Playground Express in MakeCode isn't truly random. It's always initialized with the same seed, so you'll get the same sequence of "random" numbers each time you boot the CPX. For example a simple program that prints 20 random numbers in the range 0-10:
input.buttonB.onEvent(ButtonEvent.Click, function () {
    for (let i = 0; i < 20; i++) {
        console.log(Math.randomRange(0, 10))
...will always start:
0,6,0,6,0,0,1,9,4,2,10,3,10,3,8,10,10,5,3,2
I don't have the hardware to test, but it looks like this is true for all SAMD21 boards (like CPX) in MakeCode. See the initRandomSeed() implementation here; the seed is fixed:
https://github.com/microsoft/pxt-common ... m.cpp#L121
As a workaround I made a function that uses the light + sound sensors to add entropy:
let rand = 0
function getRandom(min: number, max: number): number {
    rand = Math.randomRange(0, 255)
    rand = rand + input.soundLevel()
    rand = rand + input.lightLevel()
    rand = rand / 3
    rand = Math.round((rand % (max - min)) + min)
    return rand
It's not perfect (for example it's only for random numbers in the range 0-255), but I figured I'd post it here in case anyone else needs more randomness from the CPX.
There's an open issue in GitHub: https://github.com/microsoft/pxt-adafruit/issues/1179
adafruit_support_carter
Re: CPX: Random number generator not random
Yep, that's the expected behavior. There is no hardware true random number generator. Seeding with sensor noise is a good work around. Some discussion about this here:
https://learn.adafruit.com/circuit-play ... dom-or-not
Return to “MakeCode”
