Servo Extension Broken?
Microsoft's MakeCode platform for easy blocks-style programming
LC_
Post by LC_ »
Forgive me if I'm missing something obvious.
I'm trying to use the servo extension in https://maker.makecode.com/ for the Feather M0 Express (although it doesn't seem to matter which board you try to use it with). When I add the servo extension, I see the servo option, but when I click it, there are no blocks. If I switch to JavaScript, there are blocks, but if I drop them into the JavaScript code, there's a "problem" stating "Property 'servos' does not exist". Am I missing something or does this extension only work for the CPX in the Adafruit MakeCode instance?
Luke
mikeysklar
Re: Servo Extension Broken?
Post by mikeysklar »
I also see MakeCode Servo examples for Feather Crickit and micro:bit in addition to CPX.
https://learn.adafruit.com/adafruit-cri ... -2989433-3
Check out our beta makecode New Project --> Advanced Extensions --> Search Bar --> Crickit
https://makecode.adafruit.com/beta
Return to “MakeCode”
