So, basically, i'm making this game where there is a slime, and when the player gets close to the slime, the slime starts following the player. The slime has a passive wandering AI, but it just never returns to that AI when it starts following the player.
So, what i want to do, is make it wait a bit after it's far away, then return to wander AI, but the problem is, i have no idea how to make it stop following the player.
In short, i need a way to make the slime stop following the player.
Any help is greatly appreciated, thanks in advance!
How do i make a sprite stop following another?
- HiroyuYulin
- blnkjns
Re: How do i make a sprite stop following another?
It's a classic state-machine problem. There are two states, wandering and chasing, and there are conditions to move between these.
So we need a variable that defines the state. Say we call it Slimestate. You decide the exact conditions. For example 1=wandering, 2=chasing.
Now you make your blocks to have an endless loop, within them an if then-else. If state=1 then it does the wandering code, if it is 2 it does the chasing code.
Then you go to the conditions. If it is close, it has to go into chasing mode. But it should only do that once: so we need something to monitor when this "collision" happened. Say we introduce a variable "chasetime". We make it 0 on boot.
In block-code you can make a separate "watchdog". It has to do the following (pseudocode):
* check how fast a routine is called, I guess 30 or 60 times a second.
You make a second watchdog that subtracts 1 from chasetime if it is greater than 0 and that when it is 0 the slimestate becomes 1 again.
Now there is a possible situation that messes up: if slime is still nearby, it will immediately jump to chasemode once more. So we also need easetime.
On start make easetime=0
So if me make chasetime 300, we also make easetime 60 (2 seconds to escape).
The second watchdog has to be altered a bit:
On start
Loop forever
If slime is nearby AND chasetime=0 then
slimestate becomes 2 (chasing mode)
chasetime becomes 300 (frames)*
easetime becomes 60 (I explain this part later)
On start
Loop forever
if chasetime>0 then
subtract 1 from chasetime
if chasetime=0 then
slimestate=1
On start
Loop forever
if chasetime>0 then
If chasetime=0 then
if easetime>0 then
subtract 1 from easetime
slimestate=1 (wander)
