MakeCode doe CPB
MakeCode doe CPB
by gallaugher on Fri Jun 04, 2021 1:13 am
I realize that MakeCode for the CircuitPlayground Bluefruit is still in beta. I’m wondering if the simulator allows for the changing of temperatures, light, or sound, or switching the slide switch on the CPB, or is this something you can’t use the simulator for and need to rely on loading and running code on a physical device. Thanks. Also - what’s the large AB circle on the simulator. It can be selected and gets a yellow outline but I’m not sure what this does.
gallaugher
Re: MakeCode doe CPB
by blnkjns on Fri Jun 04, 2021 3:59 am
I see a microphone component on that spot. And it gets a yellow line if I drag the block "on loud sound".
blnkjns
by johnpark on Fri Jul 09, 2021 12:10 pm
The AB button should be the simulator's way of allowing you to press the A and B buttons at the same time.
johnpark
