It's Holiday Sale Weekend at Adafruit - use the code ADATY to get 15% off items storewide! Some restrictions apply.
Corrupt screen on Clue
by wmerkens on Sun Oct 24, 2021 1:55 am
I have a new Clue but after loading Circuitpython 7 and the required libs, then running the spirit demo the screen is always corrupt. I reformat the unit and redid all the steps to set it up but it's still corrupt. I have attached a pic.
wmerkens
Re: Corrupt screen on Clue
by adafruit_support_carter on Tue Oct 26, 2021 12:45 pm
Can't really make out what is happening in that photo. It looks like there is some kind of output on the screen at least? But can't see what. Can you post a higher res photo.
by wmerkens on Tue Oct 26, 2021 7:06 pm
This forum only allows 1MB pics but what you see is accurate, the screen is that faint and you cannot read anything clear on it.
Another pic of the corruption
Just in case that does not do it, here is a google link
https://photos.app.goo.gl/mrkrdFjXmXraFXAn8
wmerkens
by adafruit_support_carter on Wed Oct 27, 2021 12:27 pm
Thanks. That photo helps. That is really weird.
As another way to test the display, try downloading the precompiled example from here:
https://learn.adafruit.com/adafruit-clue/arduino-test
Download the UF2 by clicking the green button that says CLUE_TEST.UF2.
You don't need Arduino to actually run the example. Double press the reset button on the CLUE to get the BOOT folder to show up, and then drag the downloaded CLUE_TEST.UF2 file to the BOOT folder. It'll reset and run once the copy is complete.
Any change to the screen?
by wmerkens on Wed Oct 27, 2021 8:50 pm
Nope, here is a new screenshot
just in case google link
https://photos.app.goo.gl/cY8Rzoch7TLZffxb9
wmerkens
by adafruit_support_carter on Thu Oct 28, 2021 11:25 am
Thanks. That test would indicate it must be something hardware related. Let's check for anything obvious with the hardware. Can you post a photo of the backside of the CLUE. Please show the whole board, but the main item of interest will be the ribbon cable:
by wmerkens on Thu Oct 28, 2021 10:30 pm
Ok here is a pic of the connector on the back.
Just in case a link to a google pic version
https://photos.app.goo.gl/iYWhkW93UF5ufELN6
wmerkens
by adafruit_support_carter on Fri Oct 29, 2021 10:33 am
Thanks. That all looks generally as it should. Not sure what's happening, let's just replace it.
Send an email to support@adafruit.com with a link to this thread and your order number and they can send you a replacement CLUE.
