Egg Drop Clue White Screen
by OSCEDU2022 on Thu Jan 27, 2022 2:46 pm
Hello, I just purchased 6 clues to do egg drop. I downloaded all the codes to one of them and it has sound and everything but the egg on the screen looks whiteish. Is there a way to fix this or does this mean malfunction of the screen?
OSCEDU2022
Re: Egg Drop Clue White Screen
by franklin97355 on Thu Jan 27, 2022 3:09 pm
Have you tried the codes to see if the other ones react the same? Which code did you use?
franklin97355
by OSCEDU2022 on Thu Jan 27, 2022 3:37 pm
3 of the 6 that I purchased have white screens. I am using the code provided by adafruit for egg drop.
OSCEDU2022
by franklin97355 on Thu Jan 27, 2022 3:43 pm
Can you post a picture of the problem?
franklin97355
by OSCEDU2022 on Thu Jan 27, 2022 3:48 pm
The screen is white and you can barely see the egg picture.
OSCEDU2022
by adafruit_support_carter on Thu Jan 27, 2022 5:54 pm
Try the pre-compiled test UF2 from here and see if it also appears different on those CLUEs:
https://learn.adafruit.com/adafruit-clue/arduino-test
You don't need Arduino installed. Just download the UF2 file, double click reset on CLUE to get BOOT folder, then drag UF2 to BOOT folder.
by adafruit2 on Fri Jan 28, 2022 2:21 am
we think this is a weird artifact with gamma correction on some screens, but it is fixable in software we think!
adafruit2
Site Admin
by OSCEDU2022 on Mon Jan 31, 2022 3:02 pm
The screen is still white after UF2. Is there anything else to fix this or should I request a replacement?
OSCEDU2022
by adafruit2 on Mon Jan 31, 2022 3:05 pm
on all 6 CLUE? or how many?
adafruit2
Site Admin
by OSCEDU2022 on Mon Jan 31, 2022 3:07 pm
3 of them
OSCEDU2022
by adafruit2 on Mon Jan 31, 2022 3:14 pm
ok thats really odd - can you flip the boards over and take a photo of the TFT connector? it sounds like maybe they got loose. 3 boards is a lot to have this very rare issue, which makes us think it could be something else. the other 3 boards loaded that UF2 just fine?
adafruit2
Site Admin
by OSCEDU2022 on Mon Jan 31, 2022 3:23 pm
These are the ones with the white screen. The other 3 clues work perfectly.
OSCEDU2022
by adafruit2 on Mon Jan 31, 2022 3:32 pm
quite odd! ok lets replace them. email support@adafruit with a link to this thread and if you are in the USA, please RMA "FORPHIL" - so we can investigate em - thanks :)
adafruit2
Site Admin
