Remove Python executable from Arduin
by blnkjns on Tue May 17, 2022 12:47 pm
I can't compile code for my Clue in the Arduino IDE.
I get errors from some Python module:
[9328] Error loading Python lib '/var/folders/gk/s9m9x2t13ys0493jh09b4k9c0000gn/T/_MEIXZqrim/libpython3.8.dylib':
Why is there Python code in Arduino libraries to begin with? I can imagine the oposite, C++ parts for low level tasks underneath Python, but Pythun under C++?
blnkjns
Re: Remove Python executable from Arduin
by dastels on Tue May 17, 2022 1:01 pm
It's for the build tooling (some of which are apparently written in Python (very common). Not for inclusion in the compiled code.
dastels
Try reinstalling Arduino.
dastels
by blnkjns on Tue May 17, 2022 2:53 pm
It's also happening on a fresh install.
Only works on Windows. Will use my work laptop for the Clue....
blnkjns
by dastels on Tue May 17, 2022 3:00 pm
Make sure all your libraries, and especially board support packages are up to date.
dastels
by blnkjns on Tue May 17, 2022 5:02 pm
Tried every variation on the Mac, 1.8.6, 1.8.13, 1.8.19, all NRF versions from ancient 0.5.0 to the latest 1.3, but now I give up. Adafruit nRF and Mac is no option. Free Clue for grabs!
blnkjns
by dastels on Tue May 17, 2022 6:53 pm
It's looking for Python 3.8. If it didn't install it itself, it must be relying on it being there. Try installing Python 3.8.
dastels
You said you're using the most recent version of MacOS?
dastels
by blnkjns on Wed May 18, 2022 1:04 am
Not the most recent MacOS, I use the best: Mojave. Lean and mean. The new direction is too much Candy Crush for me and under Mojave my vintage 2015 MBP has roughly the same battery life as a new M1 MBA and boots as fast. So there has been injected some bloat along the way.
How comes the Adafruit nRF boards look for Python, where ATSAMD/Atmel boards compile without a hiccup?
blnkjns
by dastels on Wed May 18, 2022 9:59 am
Yes, the Nordic toolchain has some python components.
dastels
by blnkjns on Wed May 18, 2022 2:27 pm
Strange enough the stuff from Sandeep compiles without issues. For example for the Microbit 2
blnkjns
by dastels on Wed May 18, 2022 3:02 pm
The Micro:bit 2 uses a different MCU. How different is the toolchain, no idea. But apparently different enough.
dastels
by blnkjns on Thu May 19, 2022 1:16 pm
Differences between nRF52832 and nRF52840 seem minimal. Zigbee support, USB 2.0 and 512kB Flash seem to be the differences.
blnkjns
by dastels on Thu May 19, 2022 1:52 pm
That says nothing about potential differences in the tooling.
dastels
by argonblue on Sat Jun 04, 2022 2:32 pm
I posted an analysis and possible workaround here.
argonblue
