Shapes error in clue
by Teddygag on Wed Mar 25, 2020 12:12 pm
Can someone please help me. I ran the following code on the clue and got the error that the fill attribute is not right. Run it yourself to see the error. If you remove the fill=clue.RED, the program displays the pentagram.
"""CLUE Polygon-pentagon"""
import board
from adafruit_clue import clue
from adafruit_display_shapes.polygon import Polygon
import displayio
display = board.DISPLAY
clue_group = displayio.Group(max_size=2)
a_polygon = Polygon([(119, 0), (233, 80), (191, 214), (48, 214), (6, 80), (119,0)], outline=clue.GREEN, fill=clue.RED)
clue_group.append(a_polygon)
while True:
    display.show(clue_group)
Teddygag
Re: Shapes error in clue
by adafruit_support_carter on Thu Mar 26, 2020 2:10 pm
The polygon shape only has an outline option:
https://github.com/adafruit/Adafruit_Ci ... gon.py#L58
so there is currently no fill option.
by Teddygag on Fri Mar 27, 2020 7:31 pm
Thank you. I got this info from reading through the shapes library. I downloaded the raw files so I could scroll through them. That way I can get the parameters for a command. Evidently the fill attribute was never implemented. Strange as the rectangle, circle,triangle,rounded rectangle shapes do have the attribute.
Either way I am a user not a developer so I accept your answer as fact. Thank you.
Teddygag
