I have installed "Adafruit CircuitPython 5.1.0 on 2020-04-02; Adafruit CLUE nRF52840 Express with nRF52840" on each, as well as the libraries called in the code example, and all supporting libraries that also arise as missing when the CLUE tries to execute the code.py example from the Learning Guide.
I have configured the first CLUE with:
- Code: Select all | TOGGLE FULL SIZE
#--| User Config |---------------------------------------------------
MY_NAME = "ME"
FRIENDS_NAME = "FRIEND"
And, the second CLUE with:
MY_NAME = "FRIEND"
FRIENDS_NAME = "ME"
I have also tried using different names ie: "ONE" and "TWO"
When running both, I only get to the "Scanning" step, and they never find or connect to each other...
Auto-reload is on. Simply save files over USB to run them or enter REPL to disable.
code.py output:
Advertising.
Waiting.
Scanning.
I have also tried with CircuitPython 5.0.
Complete code example from Clue 1:
import time
import displayio
import terminalio
from adafruit_clue import clue
from adafruit_display_text import label
import adafruit_imageload
from adafruit_ble import BLERadio
from adafruit_ble.advertising.standard import ProvideServicesAdvertisement
from adafruit_ble.services.nordic import UARTService
MY_NAME = "ME"
WAIT_FOR_DOUBLE = 0.05
DEBOUNCE = 0.25
# Define Morse Code dictionary
morse_code = {
".-" : "A", "-..." : "B", "-.-." : "C", "-.." : "D", "." : "E",
"..-." : "F", "--." : "G", "...." : "H", ".." : "I", ".---" : "J",
"-.-" : "K", ".-.." : "L", "--" : "M", "-." : "N", "---" : "O",
".--." : "P", "--.-" : "Q", ".-." : "R", "..." : "S", "-" : "T",
"..-" : "U", "...-" : "V", ".--" : "W", "-..-" : "X", "-.--" : "Y",
"--.." : "Z",
# BLE Radio Stuff
ble = BLERadio()
uart_service = UARTService()
advertisement = ProvideServicesAdvertisement(uart_service)
ble._adapter.name = MY_NAME #pylint: disable=protected-access
# Display Stuff
display = clue.display
disp_group = displayio.Group()
display.show(disp_group)
# Background BMP with the Morse Code cheat sheet
bmp, pal = adafruit_imageload.load("morse_bg.bmp",
bitmap=displayio.Bitmap,
palette=displayio.Palette)
disp_group.append(displayio.TileGrid(bmp, pixel_shader=pal))
# Incoming messages show up here
in_label = label.Label(terminalio.FONT, text='A'*18, scale=2,
color=0x000000)
in_label.anchor_point = (0.5, 0)
in_label.anchored_position = (65, 12)
disp_group.append(in_label)
# Outging messages show up here
out_label = label.Label(terminalio.FONT, text='B'*18, scale=2,
color=0x000000)
out_label.anchor_point = (0.5, 0)
out_label.anchored_position = (65, 190)
disp_group.append(out_label)
# Morse Code entry happens here
edit_label = label.Label(terminalio.FONT, text='....', scale=2,
color=0x000000)
edit_label.anchor_point = (0.5, 0)
edit_label.anchored_position = (105, 222)
disp_group.append(edit_label)
def scan_and_connect():
Advertise self while scanning for friend. If friend is found, can
connect by pressing A+B buttons. If friend connects first, then
just stop.
Return is a UART object that can be used for read/write.
print("Advertising.")
central = False
ble.start_advertising(advertisement)
print("Waiting.")
friend = None
while not ble.connected:
if friend is None:
print("Scanning.")
in_label.text = out_label.text = "Scanning..."
for adv in ble.start_scan():
if ble.connected:
# Friend connected with us, we're done
ble.stop_scan()
break
if adv.complete_name == FRIENDS_NAME:
# Found friend, can stop scanning
ble.stop_scan()
friend = adv
print("Found", friend.complete_name)
in_label.text = "Found {}".format(friend.complete_name)
out_label.text = "A+B to connect"
break
else:
if clue.button_a and clue.button_b:
# Connect to friend
print("Connecting to", friend.complete_name)
ble.connect(friend)
central = True
# We're now connected, one way or the other
print("Stopping advertising.")
ble.stop_advertising()
# Return a UART object to use
if central:
print("Central - using my UART service.")
return uart_service
else:
print("Peripheral - connecting to their UART service.")
for connection in ble.connections:
if UARTService not in connection:
continue
return connection[UARTService]
# The main application loop
while True:
# Establish initial connection
uart = scan_and_connect()
print("Connected.")
code = ''
in_label.text = out_label.text = ' '*18
edit_label.text = ' '*4
done = False
# Run the chat while connected
while ble.connected:
# Check for incoming message
incoming_bytes = uart.in_waiting
if incoming_bytes:
bytes_in = uart.read(incoming_bytes)
print("Received: ", bytes_in)
in_label.text = in_label.text[incoming_bytes:] + bytes_in.decode()
# DOT (or done)
if clue.button_a:
start = time.monotonic()
while time.monotonic() - start < WAIT_FOR_DOUBLE:
if clue.button_b:
done = True
if not done and len(code) < 4:
print('.', end='')
code += '.'
edit_label.text = "{:4s}".format(code)
time.sleep(DEBOUNCE)
# DASH (or done)
if clue.button_b:
if clue.button_a:
done = True
print('-', end='')
code += '-'
# Turn Morse Code into letter and send
if done:
letter = morse_code.get(code, ' ')
print(' >', letter)
out_label.text = out_label.text[1:] + letter
uart.write(str.encode(letter))
code = ''
done = False
print("Disconnected.")
Complete code example from Clue 2:
import time
import displayio
import terminalio
MY_NAME = "FRIEND"
FRIENDS_NAME = "ME"
DEBOUNCE = 0.25
morse_code = {
"--.." : "Z",
# BLE Radio Stuff
ble = BLERadio()
# Display Stuff
color=0x000000)
color=0x000000)
color=0x000000)
just stop.
central = False
print("Waiting.")
friend = None
if friend is None:
print("Scanning.")
if ble.connected:
ble.stop_scan()
break
ble.stop_scan()
friend = adv
break
else:
# Connect to friend
ble.connect(friend)
central = True
if central:
return uart_service
else:
continue
while True:
print("Connected.")
code = ''
done = False
if incoming_bytes:
# DOT (or done)
if clue.button_a:
if clue.button_b:
done = True
print('.', end='')
code += '.'
# DASH (or done)
if clue.button_b:
if clue.button_a:
done = True
print('-', end='')
code += '-'
if done:
print(' >', letter)
code = ''
done = False
Suggestions on what I might be missing or doing wrong?
