CircuitPython BLE Morse Code Chat Example
by adafruitguy on Fri Apr 03, 2020 1:40 am
I have two Adafruit CLUE's, and I am attempting to use the CircuitPython BLE Morse Code Chat https://learn.adafruit.com/circuitpython-ble-wireless-morse-code-chat example.
I have installed "Adafruit CircuitPython 5.1.0 on 2020-04-02; Adafruit CLUE nRF52840 Express with nRF52840" on each, as well as the libraries called in the code example, and all supporting libraries that also arise as missing when the CLUE tries to execute the code.py example from the Learning Guide.
I have configured the first CLUE with:
#--| User Config |---------------------------------------------------
MY_NAME = "ME"
FRIENDS_NAME = "FRIEND"
And, the second CLUE with:
MY_NAME = "FRIEND"
FRIENDS_NAME = "ME"
I have also tried using different names ie: "ONE" and "TWO"
When running both, I only get to the "Scanning" step, and they never find or connect to each other...
code.py output:
Advertising.
Waiting.
Scanning.
I have also tried with CircuitPython 5.0.
Complete code example from Clue 1:
import time
import displayio
import terminalio
from adafruit_clue import clue
from adafruit_display_text import label
import adafruit_imageload
from adafruit_ble import BLERadio
from adafruit_ble.advertising.standard import ProvideServicesAdvertisement
from adafruit_ble.services.nordic import UARTService
MY_NAME = "ME"
WAIT_FOR_DOUBLE = 0.05
DEBOUNCE = 0.25
# Define Morse Code dictionary
morse_code = {
    ".-"   : "A", "-..." : "B", "-.-." : "C", "-.."  : "D", "."    : "E",
    "..-." : "F", "--."  : "G", "...." : "H", ".."   : "I", ".---" : "J",
    "-.-"  : "K", ".-.." : "L", "--"   : "M", "-."   : "N", "---"  : "O",
    ".--." : "P", "--.-" : "Q", ".-."  : "R", "..."  : "S", "-"    : "T",
    "..-"  : "U", "...-" : "V", ".--"  : "W", "-..-" : "X", "-.--" : "Y",
    "--.." : "Z",
# BLE Radio Stuff
ble = BLERadio()
uart_service = UARTService()
advertisement = ProvideServicesAdvertisement(uart_service)
ble._adapter.name = MY_NAME #pylint: disable=protected-access
# Display Stuff
display = clue.display
disp_group = displayio.Group()
display.show(disp_group)
# Background BMP with the Morse Code cheat sheet
bmp, pal = adafruit_imageload.load("morse_bg.bmp",
                                   bitmap=displayio.Bitmap,
                                   palette=displayio.Palette)
disp_group.append(displayio.TileGrid(bmp, pixel_shader=pal))
# Incoming messages show up here
in_label = label.Label(terminalio.FONT, text='A'*18, scale=2,
                       color=0x000000)
in_label.anchor_point = (0.5, 0)
in_label.anchored_position = (65, 12)
disp_group.append(in_label)
# Outging messages show up here
out_label = label.Label(terminalio.FONT, text='B'*18, scale=2,
                        color=0x000000)
out_label.anchor_point = (0.5, 0)
out_label.anchored_position = (65, 190)
disp_group.append(out_label)
# Morse Code entry happens here
edit_label = label.Label(terminalio.FONT, text='....', scale=2,
                         color=0x000000)
edit_label.anchor_point = (0.5, 0)
edit_label.anchored_position = (105, 222)
disp_group.append(edit_label)
def scan_and_connect():
    Advertise self while scanning for friend. If friend is found, can
    connect by pressing A+B buttons. If friend connects first, then
    just stop.
    Return is a UART object that can be used for read/write.
    print("Advertising.")
    central = False
    ble.start_advertising(advertisement)
    print("Waiting.")
    friend = None
    while not ble.connected:
        if friend is None:
            print("Scanning.")
            in_label.text = out_label.text = "Scanning..."
            for adv in ble.start_scan():
                if ble.connected:
                    # Friend connected with us, we're done
                    ble.stop_scan()
                    break
                if adv.complete_name == FRIENDS_NAME:
                    # Found friend, can stop scanning
                    ble.stop_scan()
                    friend = adv
                    print("Found", friend.complete_name)
                    in_label.text = "Found {}".format(friend.complete_name)
                    out_label.text = "A+B to connect"
                    break
        else:
            if clue.button_a and clue.button_b:
                # Connect to friend
                print("Connecting to", friend.complete_name)
                ble.connect(friend)
                central = True
    # We're now connected, one way or the other
    print("Stopping advertising.")
    ble.stop_advertising()
    # Return a UART object to use
    if central:
        print("Central - using my UART service.")
        return uart_service
    else:
        print("Peripheral - connecting to their UART service.")
        for connection in ble.connections:
            if UARTService not in connection:
                continue
            return connection[UARTService]
# The main application loop
while True:
    # Establish initial connection
    uart = scan_and_connect()
    print("Connected.")
    code = ''
    in_label.text = out_label.text = ' '*18
    edit_label.text = ' '*4
    done = False
    # Run the chat while connected
    while ble.connected:
        # Check for incoming message
        incoming_bytes = uart.in_waiting
        if incoming_bytes:
            bytes_in = uart.read(incoming_bytes)
            print("Received: ", bytes_in)
            in_label.text = in_label.text[incoming_bytes:] + bytes_in.decode()
        # DOT (or done)
        if clue.button_a:
            start = time.monotonic()
            while time.monotonic() - start < WAIT_FOR_DOUBLE:
                if clue.button_b:
                    done = True
            if not done and len(code) < 4:
                print('.', end='')
                code += '.'
                edit_label.text = "{:4s}".format(code)
                time.sleep(DEBOUNCE)
        # DASH (or done)
        if clue.button_b:
                if clue.button_a:
                    done = True
                print('-', end='')
                code += '-'
        # Turn Morse Code into letter and send
        if done:
            letter = morse_code.get(code, ' ')
            print(' >', letter)
            out_label.text = out_label.text[1:] + letter
            uart.write(str.encode(letter))
            code = ''
            done = False
    print("Disconnected.")
Complete code example from Clue 2:
import time
import displayio
import terminalio
MY_NAME = "FRIEND"
FRIENDS_NAME = "ME"
DEBOUNCE = 0.25
morse_code = {
    "--.." : "Z",
# BLE Radio Stuff
ble = BLERadio()
# Display Stuff
                       color=0x000000)
                        color=0x000000)
                         color=0x000000)
    just stop.
    central = False
    print("Waiting.")
    friend = None
        if friend is None:
            print("Scanning.")
                if ble.connected:
                    ble.stop_scan()
                    break
                    ble.stop_scan()
                    friend = adv
                    break
        else:
                # Connect to friend
                ble.connect(friend)
                central = True
    if central:
        return uart_service
    else:
                continue
while True:
    print("Connected.")
    code = ''
    done = False
        if incoming_bytes:
        # DOT (or done)
        if clue.button_a:
                if clue.button_b:
                    done = True
                print('.', end='')
                code += '.'
        # DASH (or done)
        if clue.button_b:
                if clue.button_a:
                    done = True
                print('-', end='')
                code += '-'
        if done:
            print(' >', letter)
            code = ''
            done = False
Suggestions on what I might be missing or doing wrong?
Here is a photo of my two CLUEs
adafruitguy
Re: CircuitPython BLE Morse Code Chat Example
by adafruit_support_carter on Fri Apr 03, 2020 1:45 pm
Hey, sorry about this. We've recreated the issue. It is related to this:
https://github.com/adafruit/Adafruit_Ci ... /issues/75
We'll fix that and get back to you once we have an update.
by adafruit_support_carter on Fri Apr 03, 2020 3:32 pm
OK, should be fixed if you update to the latest library release:
https://github.com/adafruit/Adafruit_Ci ... /tag/6.1.1
You can either grab it from that release page or wait until tomorrow and it will be in the bundle.
by adafruitguy on Fri Apr 03, 2020 6:00 pm
The fix worked flawlessly, thank you!
adafruitguy
by adafruit_support_carter on Fri Apr 03, 2020 6:23 pm
Awesome! Glad that fixed it. Thanks for letting us know. Have fun!
