Hi. i can't compile the arcada library with the exemple code in arduino IDE
In file included from D:\Documents\Arduino\libraries\arduino_203858/Adafruit_Arcada.h:21:0,
from D:\Documents\Arduino\libraries\arduino_203858\examples\graphicstest\graphicstest.ino:1:
D:\Documents\Arduino\libraries\arduino_203858/Boards/Adafruit_Arcada_Clue.h: In member function 'virtual bool Adafruit_Arcada::variantBegin()':
D:\Documents\Arduino\libraries\arduino_203858/Boards/Adafruit_Arcada_Clue.h:37:12: error: 'class Adafruit_Sensor' has no member named 'printSensorDetails'
accel->printSensorDetails();
D:\Documents\Arduino\libraries\arduino_203858\examples\graphicstest\graphicstest.ino: In function 'void setup()':
D:\Documents\Arduino\libraries\arduino_203858\examples\graphicstest\graphicstest.ino:22:397: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
testdrawtext("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla sed malesuada et, malesuada sit amet turpis. Sed porttitor neque ut ante pretium vitae malesuada nunc bibendum. Nullam aliquet ultrices massa eu hendrerit. Ut sed nisi lorem. In vestibulum purus a tortor imperdiet posuere. ", ARCADA_WHITE);
CLUE- error while arcada
- dastels
Re: CLUE- error while arcada
The first step is to make sure you have everything up to date: Arduino IDE, board support, and libraries. It looks likely that you have a mix of newer and older libraries.
- Vstudio_LAB
Hi! I updated all the libraries, but still not compilling...
In file included from D:\Documents\Arduino\libraries\Adafruit_Arcada_Library/Adafruit_Arcada.h:21:0,
from D:\Documents\Arduino\libraries\Adafruit_Arcada_Library\examples\full_board_tests\arcada_clue_test\arcada_clue_test.ino:1:
D:\Documents\Arduino\libraries\Adafruit_Arcada_Library/Boards/Adafruit_Arcada_Clue.h: In member function 'virtual bool Adafruit_Arcada::variantBegin()':
D:\Documents\Arduino\libraries\Adafruit_Arcada_Library/Boards/Adafruit_Arcada_Clue.h:37:12: error: 'class Adafruit_Sensor' has no member named 'printSensorDetails'
- dastels
I've seen others who have had multiple versions of the sensor library on their drive. Turn on all warnings in the prefs, and look at the output for warning of finding multiple alternatives. If that's the problem, it could be picking up an old/wrong one, leading to the missing method error.
- Vstudio_LAB
That was that! problem solved!
