Creating BMP files for CLUE
by DarTheMadScientist on Fri Apr 24, 2020 4:16 pm
I'm having trouble getting a BMP file to load. I think I have the right size. Maybe I have the wrong color depth.
I am doing this:
# Add an image to the layer group
image, palette = adafruit_imageload.load("Covid Watch logo 240x240.bmp",
                                   bitmap=displayio.Bitmap,
                                   palette=displayio.Palette)
And what I get is this:
  File "main.py", line 21, in <module>
  File "adafruit_imageload/__init__.py", line 61, in load
  File "adafruit_imageload/__init__.py", line 52, in load
  File "adafruit_imageload/bmp/__init__.py", line 62, in load
NotImplementedError: True color BMP unsupported
Do I need to change the color depth in the file? Any recommendations on tools that can do that?
Is there a better way to load the file and have a palette calculated for it?
DarTheMadScientist
Re: Creating BMP files for CLUE
by kevinjwalters on Sun Apr 26, 2020 6:40 pm
kevinjwalters
by adafruit_support_carter on Mon Apr 27, 2020 6:55 pm
And here are some tips for using GIMP:
https://learn.adafruit.com/circuit-play ... sheets-5-1
The trick is to save the BMP as indexed.
by DarTheMadScientist on Mon Apr 27, 2020 7:56 pm
Thank you, both of you.
I'm on Mac, so I'm going to try ffmpg. Just downloaded it.
But I do have Windows on real and virtual machines, so that is a possibility.
Hmmm. Gimp. I don't have it. Yet. I will check out the tips.
DarTheMadScientist
by adafruit_support_carter on Tue Apr 28, 2020 2:58 pm
GIMP is just the free Photoshop. If you have the later, it will also work.
by kevinjwalters on Tue Jun 09, 2020 10:40 am
I just noticed a surprise in GIMP for an external file. I loaded in a png image which was generated from MakeCode Arcade and converted that to an indexed format. I left the palette size at the default size of 255 knowing I only had four colours in there. On inspection, I found the colours varied a little around those four colours giving a larger palette - this may not be visually obvious. I left dithering set to None on the indexed converstion but I suspect this is some sort of dithering related to other colourspace conversions. I undid that and then reconverted with four colours and the bmp file is smaller now.
You can check the palette in GIMP for an indexed image with Windows > Dockable Dialogs > Colormap.
kevinjwalters
by kevinjwalters on Mon Jun 15, 2020 3:04 pm
kevinjwalters
