Clue_Plotter Problem
by geotek on Wed May 06, 2020 7:44 pm
Greetings:
Downloaded CircuitPython and libraries for plotting,etc.
Additional files loaded for plotting : Clue-Plottter changed to code.py / Plot_Source and Plottter.py
I get a few errors reported back to the display screen
File "code.py", line 47 in <module>
File "adafruit_clue.py", line 66, in <module>
ImportError: no module named 'adafruit_bmp280'
code done running. waiting for reload
I don't see any obvious problem in line 47 or line 66
The file adafruit_bmp280 does indeed appear in the LIB folder in drive D:
Has anyone come across this problem?
Any ideas for solving this problem.
Any help would be greatly appreciated!
thanks
Tom
geotek
Re: Clue_Plotter Problem
by dastels on Wed May 06, 2020 9:41 pm
Double check that adafruit_bmp280.mpy is in CIRCUITPY/lib. CircuitPython can't find it for some reason.
I just followed the instructions and it worked fine.
You might have versioning problems. I suggest you install the latest version of CircuitPython for the CLUE from https://circuitpython.org/board/clue_nrf52840_express/, as well as the latest version of the required libraries from https://circuitpython.org/libraries. (the 5.X bundle).
dastels
by geotek on Thu May 07, 2020 11:50 am
Greetings:
Thanks Dave
I reloaded the clue.py and bmp_280.py files from the source you provided and all works great.
Thanks again for your help
Tom
geotek
by dastels on Thu May 07, 2020 1:16 pm
Excellent!
dastels
by kevinjwalters on Tue May 12, 2020 6:06 am
The first time I copied the libraries in I copied adafruit_bme280.mpy (wrong one with an e) rather than adafruit_bmp280.mpy (right one with a p).
kevinjwalters
by geotek on Tue May 12, 2020 8:36 am
Greetings
Once I recopying the correct files, it worked like a charm.
The Clue is pretty cool little board with a lot of potential
Tom
geotek
by dastels on Tue May 12, 2020 9:56 am
Kevin, I've done that as well.
dastels
by RobertI on Fri Jul 03, 2020 10:36 am
Trying this as a first Clue project.
Libraries all in.
It's running.
Draws the frame.
But it just gets a MemoryError trying to allocate 161 bytes at code.py 162/line 786 of plotter.py.
Any suggestions? I'm so near yet so far...
RobertI
by kevinjwalters on Fri Jul 03, 2020 10:40 am
I have some familiarity with this project, I'll run it up on 5.3.0 and latest libs to see how it behaves.
@Robertl What version of CircuitPython and library bundle are you using?
kevinjwalters
by RobertI on Fri Jul 03, 2020 11:34 am
"some familiarity" indeed. Thank you.
I'm using the most recent uploads of both - from adafruit-circuitpython-bundle-5.x-mpy-20200703.
Also running it from a Mac - am aware that the mac OS sometimes sticks BS in the files...
Thank you!
Robert
RobertI
by kevinjwalters on Fri Jul 03, 2020 11:58 am
I get this too on same libraries.
Adafruit CircuitPython 5.3.0 on 2020-04-29; Adafruit CLUE nRF52840 Express with nRF52840
soft reboot
Auto-reload is on. Simply save files over USB to run them or enter REPL to disable.
code.py output:
  File "code.py", line 195, in <module>
  File "code.py", line 162, in popup_text
  File "plotter.py", line 786, in info
  File "adafruit_display_text/label.py", line 127, in __init__
  File "adafruit_display_text/label.py", line 271, in _update_text
  File "adafruit_display_text/label.py", line 167, in _create_background_box
MemoryError: memory allocation failed, allocating 1616 bytes
There's a problem somewhere between the plotting application and one of its libraries. For now, I would advise using an older version of just the lib/adafruit_display_text/label.py library as a workaround. The one I did the majority of my development and testing on is adafruit-circuitpython-bundle-5.x-mpy-20200327.zip found in https://github.com/adafruit/Adafruit_Ci ... g/20200327 . I've tried this (see below for how I renamed current version) and can confirm it works.
lib/adafruit_display_text directory showing 20200327 label.mpy with newer version renamed
I also tried commenting out popup_text() for the Button Guide which appeared to help at first but then the text after that in the plotter went a bit crazy position-wise so this does not help. I'll dig a bit deeper here to see what's going on here.
kevinjwalters
by RobertI on Fri Jul 03, 2020 12:22 pm
You are a fine and splendid person.
RobertI
by RobertI on Fri Jul 03, 2020 12:35 pm
All working fine now. Except there is a hilarious glitch in the temperature plotting, the start of every sweep is much lower than later; but I say this as an aside, because the purpose of the program is to try out the device, and the device is great.
RobertI
by kevinjwalters on Fri Jul 03, 2020 12:47 pm
I believe it's how the sensor works, my hypothesis for these very small variations is described on CLUE Sensor Plotter in CircuitPython: Sensors: Temperature. Happy plotting.
BTW, I put in a ticket for the MemoryError, if you're interested you can track GitHub: adafruit/Adafruit_CircuitPython_Display_Text: Consider offering control over creation of background bitmap to reduce memory usage #61.
kevinjwalters
by RobertI on Fri Jul 03, 2020 12:54 pm
Thank you, I will. My own code next tho'
RobertI
