First look was the CLUE factory sketch - under RTOS but just the loop() task - it takes 540+ms to cycle through a display update loop without any delay - that is scary slow for what I hoped to see. So other timing tests. A Teensy 3.2 at 48 Mhz was faster - similar M4 - NRF designed for low power with Float support.
Reading the RTOS related code the loop() is started TASK_PRIO_LOW not NORMA?. Adding a second task loop2() and other adventures as in the code below got the count of loop()'s second up - the second task helped, but not sure if legal - but so did adding a new/second :: Scheduler.startLoop(loop);
But when instantiated with params as indicated in the code - just added according to the read.me - things act like that was not properly implemented?
Purchase here was some SENSE and CLUE both - and they both respond the same. If the #defines are cycled in one by one the effect on the runtime is observable as noted in comments.
Two other issues - perhaps for other threads
> in setup() the resolution of micros() is tested and noted to be 976us per micros() tick - I didn't look at the implementation - but that is really bad at almost 1ms for a function that takes longer to return
> The CLUE with " pinMode( PIN_LED2, OUTPUT ); " starts the the white LEDS ON - as shown in code digitalWrite( PIN_LED2, 0 ); executed before didn't turn them on until used later.
Here is the code used showing the RTOS confusion- loop() and loop2() are simple calls to LED toggle as in the one example - showing the cycle time. Where the blinks are made no delay(). This will be an issue adding 'tasks' when Bluetooth also adds a task I suspect - but haven't gotten that far yet.
- Code: Select all | TOGGLE FULL SIZE
// FOR SENSE :::
#define SHOWBAD 1 // ONLY runs loop() and not loop2() // 177K
//#define SHOWBROKEN 1 // Never runs loop() only loop2() // 87K each
//#define DUALGOOD 1 // 170K
//#define DUALBETTER 1 // 172K
// DEFAULT ELSE // 170K
// FOR CLUE :::
//#define SHOWBAD 1 // ONLY runs loop() and not loop2() // 176K
//#define SHOWBROKEN 1 // Never runs loop() only loop2() // 86K each
//#define DUALGOOD 1 // 169K
// DEFAULT ELSE // without loop2() Scheduler // 169K
// NRF52 micros() are 976us apart - and take extra runtime
#ifdef ARDUINO_NRF52840_CLUE
#define OTHERLED PIN_LED2 // CLUE front whites
#endif
#ifdef ARDUINO_NRF52840_FEATHER_SENSE
#define OTHERLED LED_BLUE
#endif
void setup()
while (!Serial && millis() < 6000) delay(10);
Serial.println("\nScheduler RTOS DualBlink test!");
Serial.println( __FILE__ " " __DATE__ " " __TIME__);
digitalWrite( OTHERLED, 0); // CLUE PIN_LED2 powers up ON ???
pinMode( OTHERLED, OUTPUT );
#ifdef SHOWBAD
Scheduler.startLoop(loop, 1024, TASK_PRIO_NORMAL , "loop");
Scheduler.startLoop(loop2, 1024, TASK_PRIO_NORMAL, "loop2"); // NEVER RUNS
#elif SHOWBROKEN
Scheduler.startLoop(loop2, 1024, TASK_PRIO_NORMAL, "loop2"); // loop() NEVER RUNS
#elif DUALBETTER
Scheduler.startLoop(loop2);
#elif DUALGOOD
#else // SINGLESLOW
// default :: loop() starts with TASK_PRIO_LOW ??
#endif
uint32_t ttest[10];
ttest[0]=micros();
for ( int ii = 0; ii < 9; ) {
if ( ttest[ii] != micros() )
ttest[++ii] = micros();
for ( int ii = 0; ii < 9; ii++ ) {
Serial.println( ttest[ii] );
Serial.println( ttest[ii+1]-ttest[ii] );
void loop() // Toggle led1 every 1 second
timeCntPrt( LED_RED, 1000 );
void loop2() // Toggle led1 every 0.5 second
timeCntPrt( OTHERLED, 500 );
void timeCntPrt( uint32_t aPin, uint32_t aWait) //
static uint32_t Waits[50], Counts[50], allCnt;
if ( 0 == Counts[aPin] ) {
Counts[aPin]++;
Waits[aPin] = millis();
else {
Counts[aPin]++;
if ( millis() - Waits[aPin] >= aWait ) {
digitalToggle(aPin);
Waits[aPin] += aWait;
Serial.printf( "\tPin#%u C#=%u\t", aPin, Counts[aPin] );
allCnt += Counts[aPin];
if ( aPin == LED_RED ) {
Serial.printf( ">>> All Counts #=%u\n", allCnt );
allCnt = 0;
Counts[aPin] = 1;
