Sensor Plotter Tutorial Throws Out of Memory Exception
by dsheeran on Tue Jul 28, 2020 5:36 pm
I just received Adabox 15 today and am playing around with the tutorials. The Sensor Plotter starts by briefly showing the Sensor Plotter title bar but then throws an out-of-memory exception allocating 1616 bytes and hangs.
Is there a fix for this? I see another thread that looks like something's been done but I cannot find a file with the fix in it.
Please advise.
Thanks.
dsheeran
Re: Sensor Plotter Tutorial Throws Out of Memory Exception
by adafruit_support_carter on Tue Jul 28, 2020 7:07 pm
Hmmm. Not sure. This looks like the other thread you mention:
viewtopic.php?f=65&t=165178#p818203
That thread mentions this issue, which I added a comment to:
https://github.com/adafruit/Adafruit_Ci ... -665335398
And it looks like maybe it's now this issue:
https://github.com/adafruit/Adafruit_Ci ... /issues/76
which is still open.
So it may be that things are still currently broken for that demo.
by adafruit_support_carter on Wed Jul 29, 2020 11:06 am
There may be some work still ongoing to fix the main underlying issue. But for now, a simple code tweak seems to be enough to get the plotter code working again:
https://github.com/adafruit/Adafruit_Le ... /pull/1192
If you go back to the Learn page:
https://learn.adafruit.com/clue-sensor- ... or-plotter
and re-download the plotter.py file, it should have the new changes. Replace the old version with the new version and it should hopefully work.
by dsheeran on Wed Jul 29, 2020 3:16 pm
That fixed it. Thanks.
dsheeran
