clue isnt working with the clue circuitpython demos
by Colonizemurcury on Sat Aug 01, 2020 12:53 pm
it says:
Code.py output:
File "code.py" , line 4, in <module>
File "adafruit_clue.py", line 968
in <module>
File "adafruit_clue.py", line 223
in __init__
TypeError: function missing required
positional argument 3
Colonizemurcury
Re: clue isnt working with the clue circuitpython demos
by dastels on Sat Aug 01, 2020 2:51 pm
Someone else just had that problem:
I found that I was importing bme280.mpy instead of bmp280.mpy.
dastels
by jamesca on Sat Aug 01, 2020 11:47 pm
I'm having the same issue.
I tried installing different library release versions. Didn't work..
I tried installing different versions of circuit python. Didn't work.
Please post if you find a solution. Thanks
jamesca
by jamesca on Sun Aug 02, 2020 12:06 am
Worked!!
Found there was two versions of neopixel showing in the search results. I copied the smaller of the two files over and it started working.
picture of search
jamesca
