White BMP and washed colors on clue
by makercademy on Mon Aug 24, 2020 12:29 pm
Hello , I been tryng to follow up the example codes on the CLUE guide but some colors seem washed and bitmaps look white mostly.
WhatsApp Image 2020-08-24 at 12.19.32 PM.jpeg (100.07 KiB) Viewed 141 times
makercademy
Re: White BMP and washed colors on clue
by adafruit_support_carter on Mon Aug 24, 2020 1:43 pm
Please try running the four UF2 test examples from here:
viewtopic.php?f=65&t=168145&start=45#p825094
Do any of those manage to get the display to show up?
To load a UF2 - double press reset to put the board in bootloader mode and then drag the UF2 file to the BOOT folder.
by makercademy on Mon Aug 24, 2020 3:44 pm
They all show a pixaleted set of colors.
makercademy
by makercademy on Mon Aug 24, 2020 3:45 pm
makercademy
by adafruit_support_carter on Mon Aug 24, 2020 3:46 pm
Thanks for running those tests. That's interesting. That sounds like it's a different behavior than some of these other cases.
Can you post a photo of the back side of the CLUE so we can see if maybe there's something happening with the hardware.
by makercademy on Mon Aug 24, 2020 3:51 pm
Yes of course!
WhatsApp Image 2020-08-24 at 3.41.39 PM.jpeg (115.31 KiB) Viewed 136 times
WhatsApp Image 2020-08-24 at 3.41.40 PM.jpeg (87.5 KiB) Viewed 136 times
makercademy
by adafruit_support_carter on Mon Aug 24, 2020 3:57 pm
Thanks. Nothing obvious there. We can replace this. But first - are you in the US? We'd be interested in also getting that one back for testing if so.
by makercademy on Mon Aug 24, 2020 4:17 pm
Yes i am in the US
makercademy
by adafruit_support_carter on Mon Aug 24, 2020 5:19 pm
OK, let's replace it and get that one sent back as well.
Send an email to support@adafruit.com with a link to this thread and your order number and they can send you a replacement CLUE. Also ask for an RMA FORPHIL to have the one you currently have sent back.
by kevinjwalters on Fri Aug 28, 2020 10:49 am
One observation here, the manufacturer's screen protector in the photo has a blue tab. My four CLUEs from two batches which do not have this problem came with red tabs...
kevinjwalters
