Bonsai Buckaroo defective motor connector design
by tlpada on Fri Aug 28, 2020 12:58 am
As instructed by @adafruit_support_carter (https://forums.adafruit.com/viewtopic.php?t=167971#p823528) I am opening yet another thread on the defective surface mount motor connector on the Bonsai Buckaroo.
There have been multiple reports of this problem:
https://forums.adafruit.com/viewtopic.php?t=168236
https://forums.adafruit.com/viewtopic.php?t=168339
https://forums.adafruit.com/viewtopic.php?t=168306
https://forums.adafruit.com/viewtopic.php?t=168467
I have 3 of these Buckaroos and they all fall out -- if you can ever get them in without breaking the tab -- from the slightest jostling. Trying to get the wires in often results in a broken plastic tab, which happened to me.
I would like at least the Buckaroo with the broken tab replaced please, but I would also like some wire connector solution from Adafruit that would actually work -- please provide 3 stemma connectors, please, if soldering them on is the only way for these to work (or any connector that will work). I had two plants die because of this problem. I think Adafruit should just recall these boards but in the interim please replace with some kind of connectors that will work.
Thanks.
tlpada
Re: Bonsai Buckaroo defective motor connector design
by adafruit2 on Tue Sep 01, 2020 10:03 pm
hi, we're sourcing high temperature connectors for a future revision.
you can solder wires to the tabs if you have a soldering iron
email support@adafruit for a refund
adafruit2
Site Admin
