CLUE error after lib update
Tonygo
Post by Tonygo »
Just updated to CP 5.3.1 and all the libraries after seeing that the CLUE library has been changed/improved.
Now I just get missing module errors that I cannot fix.
  File "main.py", line 8, in <module>
  File "adafruit_clue.py", line 71, in <module>
ImportError: no module named 'adafruit_lsm6ds.lsm6ds33'
I've tried the examples: "spirit level" and "sensor data"
Some suggestions, please.
adafruit_support_carter
Re: CLUE error after lib update
That looks like a library issue. How did you do the library update?
Tonygo
Post by Tonygo »
I used a Windows 10 machine.
I unzipped the new lib files into one window and dragged them, one at a time, onto another window with the CLUE. lib files exposed. Each time I said replace the file.
I've always done it this way, so I don't miss one, and it has worked previously. There is no new lib for - lsm6ds ?
"new" would depend on when you last did a library update. You can see the releases here:
https://github.com/adafruit/Adafruit_Ci ... S/releases
Based on the text in the error message, it looks like you are using an older version of the LSM6DS library.
For libraries that are more than one file, like the LSM6DS, be sure to update the entire folder. Not just a single file within that folder.
Tonygo
Post by Tonygo »
pybadger is also missing from the new lib list.
Which bundle version are you using? I just checked the adafruit-circuitpython-bundle-5.x-mpy-20200901.zip release and it contains the pybadger library.
Tonygo
Post by Tonygo »
Thanks for your help. It is working now.
Return to “CLUE Board”
