Proper CLUE CP Libraries?
by blackfridayfaust on Sat Nov 21, 2020 10:49 am
What are the proper CLUE libraries for Circuit Python?
How do I know which libraries to use?
I am attempting: <https://learn.adafruit.com/adafruit-bonsai-buckaroo/clue-and-circuitpython-usage>
I am getting an error in running code.py because 'adafruit_clue.mpy" is not compatible.
The recommended resolution is to update my CircuitPython base and libraries. That does not appear to be working, so I'm wondering if I am using the wrong libraries.
According to CircuitPython.org <https://circuitpython.org/board/clue_nrf52840_express/> I should be running the latest stable release (6.0.0).
A similar user had this problem <https://forums.adafruit.com/viewtopic.php?f=65&t=169038&p=827213&hilit=lib+update#p827213> but resolved the issue with the 5.x libraries.
Did CLUE roll over from the 5.x to 6.x libraries?
blackfridayfaust
Re: Proper CLUE CP Libraries?
by asyork on Sat Apr 10, 2021 3:49 am
I wanted to bump this because I am having the same issue following the instructions in https://learn.adafruit.com/digital-nose-gas-sensor-milk-freshness-checker.
asyork
by asyork on Sat Apr 10, 2021 6:50 am
I solved this issue by using the 7.0.0-alpha.1 and corresponding libraries, but ran into another problem to be dealt with tomorrow.
asyork
